Paint over chrome grill. Does it stick?
Have you guys who collormatched their grille painted over the chrome or did you buy a paintable shell?
If painted over chrome, how did it turn out? Has it peeled at all?
^i think the guys that paint the chrome on their trucks have it sandblasted first, then primed, then painted....
im sure theres some that just paint it, but sandblasting it first is the way to go
Well either vacuum metalized or spray-chrome silver nitrate, could be the former but I always assumed the latter would be cheapest. To be honest now you've got me doubting, I'll try to find out for sure what the process is.
I'm in the same boat as you on color matching. Looks like 2 choices really, order one from GM already painted Red about $300, or find a W/T one and spray it yourself. I'd give you the pn for the red one but it's at home. They are available from GM as an accessory.
I think if you try to take the chrome off of the one you have it will probably screw up the plastic. Good luck.
The steps i used were ; sanded, 4 coates of adhesion promoter, 4 coats of primer, 4 coats of paint and 4 coats of clear coat.
Before
After
Deff worth doing wouldnt you say.
Before
After
Baltimore Whore
Looks good ^^^^^. I do believe it is chrome, not painted on. You can sand it off. Follow the steps the dude above me did, it will be just like it was from the factory. But no you can not paint over the chrome, it hold up for any period of time...
