Painting the black plastic stuff...
use th prompter first then put three good wet coats wait bout 5-10 min flash time the sand with 320 repeat til texture gone then water sand it with a 600 grit them hammer the clear if ur doing clear...put ont good wet slick coat of clear n sand it with a 1500 n reclear it .....make sure ur fan it about 8-10'' away from the part for sexy slick finish
I agree w/. this post Billy, sounds like how I'd do it for the most part. You want a little surface scuff on substrate that a proper grit provides but no so fine like someone previously said (not 1500 IMO) for paint to adhere.
Plastic parts are kinda funny, unlike metal cause they get this static thing goin where the fibers stand on end; if you've done it before, u know what I mean. Therefore I prefer to wetsand em. A tack coat 1st before u douse heavier coats. Multiple thin coats are better than heavy thick coats, esp. w/. say a metallic base. Clear is a different animal as it flows out so to speak. I can do easier than I can explain.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
Do 2 things above all.
1)Prep - that is the key to everything in life. Here too.
2)Use an adhesion promoter on this. Otherwise, I wouldn't do the job.
Terry, duct tape & a hammer, huh?!?
![hmm](https://www.performancetrucks.net/forums/images/smilies/hmm.gif)
![Icon Rolleyes](https://www.performancetrucks.net/forums/images/smilies2/icon_rolleyes.gif)
Why not just press those lil pins back in by applyin hand pressure?
When dry.
I'm planning on doing this same thing to my grille, door handles, and mirror caps this summer.
My buddy who's probably going to help out (and shoot a bit himself) when I shoot your truck works at a body shop, maybe the 3 of us can have a sanding party.![Icon Lol](https://www.performancetrucks.net/forums/images/smilies2/icon_lol.gif)
I think you might have met him at the ETown swap meet last spring?
Sanding party sounds...fun?
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by 06murder
use th prompter first then put three good wet coast wait bout 5-10 min flash time the sand with 320 repeat til texture gone then water sand it with a 600 grit them hammer the clear if ur doing clear...put ont good wet slick coat of clear n sand it with a 1500 n reclear it .....make sure ur fan it about 8-10'' away from the part for sexy slick finish
I know that plastic is tricky, and no, I've never done it before. I've seen enough refinished bumpers with the paint chipping off and looking like
![turd](https://www.performancetrucks.net/forums/images/smilies2/turd.gif)
I agree 1000% that PREP IS THE KEY!
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
I met one of your friends at the swap meet last spring, same guy?
Although, sanding with others isn't as bad as sanding alone...beer helps me sand better ![Icon Lol](https://www.performancetrucks.net/forums/images/smilies2/icon_lol.gif)
Sounds good guys...should I use clear?
that I know that I don't want mine to look like that.
I learned that a long time ago when my step father worked a second job at a body shop.
Baltimore Whore
Yes use clear for sure.. Only issues i see with plastic chipping is the areas that flex alot, when you do not use a paint with the flex additive in there... Other wise PREP PREP PREP.. You can manipulate the paint in the end, if the finish is shitty, but whats under it you can not.. NOW QUIT ALL THE TYPING AND GET TO IT..
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
i paint cars n plastic **** everyday....if u want it to pop then use 1000-1500 then reclear.. trust me it will pop if done right..fyi it u want make it go a bit faster you can 240 theres not much differce to 320...
Here is my contribution. Everything I have matched on my truck I did myself and I am NOT a pro by any means. lol
https://www.performancetrucks.net/fo...d.php?t=460462
