Painting HD hood.
#22
It sprayed ok I didn't know anybody with a 2.0 nozzle. I tried to locate one but it didn't work out. It laid down good. I just block sanded with 1000 to make sure it was nice and smooth for the paint. I'd hate to mess with the settings now on the gun cause it sprayed so well. The only reason I have the one thin spot is because I stupidly didn't stand in front o the hood and spray the back lip. Had I done that it woul have covered it. The biggest issue I've had so far was from the spray can self etch. It laid down like non skid. But after I knocked down the bumps the actual primer went down good.
#23
I just happen to have read the stovebolt link last night. That's why I did the test an all this morning. I had to adjust the needle a bit but it mad a nice pattern with tiny particles leading away. I took a pic of the test but I can't seemto load it on here from my phone.
#27
u can wet sand the figure print out and put a light coat of base on it,but you to wait till its dried then cleadr,u only can let it seat for 24 hrs now after that u have to sand or wet the whole hood....
#28
i hit it with some 1000 then i recoated. it actually came out good. the underside came out like glass but the top not so much. it looks good but it needs some wet sanding and buffing.
here are a few picks from stock till now.
gmcyukon
10-03-2015 11:03 PM
