Painting plastic
Originally Posted by RedVHO
Now I like this one. I read on the website it is designed around the factory fog lights. Also, I REALLY want to get an intercooled ProCharger at some point, and that opening would be perfect for a FMIC. However, I don't like looks the opening in the center without an intercooler in it.
I will probably try painting the cap and air dam first. It will only cost me a pint of paint. Then, when I get the ProCharger, some day , I'll get the Xenon cover and mount the IC in the opening. Polished of course.
heres what the inside of thecbumper looked like after only 1 year
mabey you can lightly sand it to remove residue, then spray the plastic adhesion promotor, use some filler primer then sand it again , and hit it with some paint. should be easier than sanding the plastic smooth.
