pic of PIAA airdam on '99 Z71
i got both airdam and foglamps at truckperformance.com
you can get them through TByrne as well
the airdam was about $169 and the lights were $139. i am estimating those numbers, not too sure. i am assuming it can be painted. it is a smooth black plastic. nothing you would have to sand down like the other bumper components on our trucks. TByrne has a picture of a green 3/4 ton at the top of this page, and also on their website. looked good with the billet grill inserts. kind of wish i did that. i put a speed grille on mine. looks fine. i don't have pics of it yet though
Looks nice im trying to get my buddy to get that on his 01 Tahoe. I bet those PIAAs out shine your headlights too, huh. I got PIAA bulbs and fogs in my Z28 i got the Super Whites love em blinds the **** out of people when I kick the high beams on.
Originally Posted by JSmith
Looks cool man! I imagine those 40 series are bright. How did you wire the lights?
You have to be very careful with PIAA bulbs they are prone to blow if not taken care of. I personally have had PIAA hi and low beam bulbs and PIAA fogs for a year and half and have never had a single bulb go out. And one of my headlight housings had a big hole in it from a truck tire that hit the front of my car. Got snow and water in there but never blew. You have to be very careful installing the bulbs because one spot of grease from human hands will prematurely end the bulbs, PIAAs run very hot compared to most other bulbs, the grease on your hands will only make that worse.
Originally Posted by KeukaZ71
i was going to use the existing wires from the stock foglamps, but i decided not to because i might get a smaller set of lights to put in the towhook openings. so i used the wires that came with the kit. it has 2 wires that connect directly to the +/- terminals on the battery, then it has another wire that you hookup inside the cab as a power supply to the on/off switch. i hooked that wire to my amp turn-on wire (using a wire tap), therefore they turn on as soon as my truck starts. no need to turn on parking/head lights. then when i turn of my truck, the lights go out. that helps so that i never leave the lights on when i am not around. the on/off switch i used 3M double sided tape to fasten it to the dash. overall, it is easy to do. it looks clean too
i definitely made sure there was no grease/oil on those bulbs. i cleaned them twice with alcohol. it just pisses my off because i was so careful with them.
KINGCYCLES
10-02-2015 10:21 AM
