Pics of Steering Column Gauge Pod ???
Old 10-25-2006, 08:02 AM
  #21
m7 rocket's Avatar
Originally Posted by TurboJohn6
Here you go BADMOFO. I can read all of my gauges clearly without any obstruction from my boost gauge. The picture does not show it that way but from my normal driving position everything is visible. I guess the height of the person driving might change the view of the gauges a little. As I said before, I did not paint mine and it blends in with the factory colors on my truck (2000) nicely. I don't know if the newer model years are different or not. IMO it is a very nice set-up. I would recommend it to anyone.
Wow, I like that. Too bad the general consensus for newer model years is don't waist your time ordering. I guess the fit is just not good enough.
Old 10-25-2006, 10:02 PM
  #22
TurboJohn6's Avatar
I just took out the screws that hold the covers in place. I believe there were 3 or 4 of them. The 2 covers bolt together like a clam shell. Once the bolts are removed, the upper cover can be moved around enough so you can make sure that you don't drill into anything behind it. I just took my time and made sure I had the clearance needed to drill. It was not hard.
I will get you a part # tomorrow. I am at work right now. I bought mine at my local speed shop not Summit. I am pretty sure Autometer only makes the one that I have though. I think the picture must be wrong. I will get back to you with the part # so that you get the right one.
Old 10-25-2006, 10:35 PM
  #23
12 Second Club
sometimes the pictures are mirrored, or look like they are reversed. I bet it is the same cover.
Old 10-25-2006, 11:22 PM
  #24
EXTREME's Avatar
summit is bad about using the same picture for numberous applications ie ford/gm/dcx. I believe the one summit has is the same one. but a part number would be a way to know for sure though!
Old 10-26-2006, 04:43 AM
  #25
Cuz I AM a BADMOFO
BADMOFO's Avatar
Thanks guys! Final question, how does the guage stay in the pods? I have a 3 pod pillar that I will also be using, but the gauge is a tad smaller than the opening, what keeps it in there? Do you put something around the gauge (tape, rubber grommet, or something) so that it fits snug in the whole or what?
Old 10-26-2006, 08:46 AM
  #26
Hunt&Fisherator
silver-mod-o's Avatar
the U shaped bracket that comes with most gauges will keep it in... you have to put the gauge in the pod before you put the pod down...
Old 10-26-2006, 10:32 AM
  #27
14 Second Truck Club
2k5Squirrel's Avatar
the part number for the steering column gauge pod is
automatic: 15007
manual: 15008
Old 10-26-2006, 10:43 AM
  #28
redLS1rado's Avatar
On mine the gauge just pushes in and it stays tight
Old 10-26-2006, 02:16 PM
  #29
TurboJohn6's Avatar
2K5Squirrel is correct...Those are the right part #'s BADMOFO. My truck is automatic so I have part # 15007. You got all the information you will need so you should be set. That is what I like about this site. Good Luck!
Old 10-27-2006, 10:05 PM
  #30
5 year bitches!
Quik's Avatar
i had pics but guess on my old PC. if you do a search youll see my gauges i use one of those colum pods for my digi tach
GXPJAY
02-13-2022 08:15 AM
nickpc82
11-02-2015 02:49 PM
chacho44
08-17-2015 03:36 AM
maxspeed05V
07-19-2015 07:08 PM
1320Chicken
07-14-2015 10:58 PM
Quick Reply: Pics of Steering Column Gauge Pod ???
