Power window conversion?
I may be purchasing an 01 Chevy LS 4x4 that has manual windows...is this easy to convert to power? It already has power locks so I am thinking it may already have the wiring harness so I can just plug n' play...would this be correct or would I need a new PCM as well?
For those who have done it...can you list the parts that were needed for the swap so I can make sure I have everything before getting started...Thanks a million in advance!
i did it on a 97. and used all factory parts. dash harness, lt + rt door harness, both regulators, both motors, all the switches, fuses, relays, door panels and trim. if you can not find this used it will be very$$$$$. i bought all new parts and it was well over $2000.00 good luck!!!
I have a buddy who has a wrecked 00 silverado that has everything I would need...I just need to get over to his house to see if the interior color pieces will match
So are you saying that I DONT need a new PCM?
lucas287
31
01-12-2021 06:18 AM
Corvette454l88
09-01-2016 01:24 AM
Superman09
09-25-2015 05:55 AM
MA$TER_E
09-09-2015 03:14 PM
