Product Review - Gunk Citrus Engine Brite
Old 09-27-2004 | 08:44 PM
XLR8NSS's Avatar
Adkoonerstrator
Damn, that stuff works pretty good. I have used Simple Green(diluted) before with good results also.
Anyone worried about spraying water under the hood don't worry. Just don't spray any high pressure, it's best to just use the hose with no nozzle on it. Never had a problem like that.
Old 09-27-2004 | 08:59 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Originally Posted by ohohsilverado
you can spray water underneath the hood???????????what parts do you have to avoid. spraying water under there with those electronics scares the crap out of me
I covered the alternator, the little red box just behind and to the right of it, and the Flex-a-lite VSC if I remember correctly. I used tin foil.
My truck isn't my daily driver so I let it sit and dry. The next morning I started her up and rolled her onto the street so she would get alot of sun. I'm sure it's totally dry under there now.
Old 09-27-2004 | 09:08 PM
Originally Posted by chevymec
I always found that if you let the engine warm up a bit it can really help break-up the crap that is stuck on good. That Gunk is some of the better stuff I used. As far as water under the hood, dont worry, I have yet to see a '99 and up have a problem with it.
I thought that also but then I read the instructions and it said the engine must be cool. I don't know, it seemed to work fine with it cool.
Old 09-27-2004 | 09:09 PM
XLR8NSS's Avatar
Adkoonerstrator
A good thing to do also is start the truck up and let the engine heat evaporate the water off. It helps to dry out spots you can't get to.
Old 09-27-2004 | 09:10 PM
XLR8NSS's Avatar
Adkoonerstrator
I think they say that cause they don't want people spraying cold water on hot engine parts. I doubt anything would happen but, you never know.
Old 09-28-2004 | 01:57 AM
CHAGO's Avatar
nice pink battery
Old 09-28-2004 | 02:46 AM
Originally Posted by ILLNALI
nice pink battery
Old 09-28-2004 | 08:39 AM
Scream's Avatar
MOOBIES Moderator
I've always used a yard blower to help dry those hard to reach spots. Works great!
Old 09-29-2004 | 12:54 AM
Totally off topic, but i knew this guy that was so **** about drying his camaro after he had it painted, he wouldn't even use a "Absorber" on it, he would drag a leaf blower around to dry the car after washing, which is fine at home, but funny as hell at a car show with people laughing.
Back on topic:
I agree also that i think they say to do it cool, because there would be some genius that would spray down his flaming hot engine with cold hose water, causing possible damage with drastic temp. change. I usually warm it up for like 5 mins at an idle, then spray her down, with just the hose, not even a nozzle, and avoid electrical parts, and clean them by hand. A little TLC goes a long way to keep the engine clean, and i just think of it this way...
"It's easier to keep an engine clean, than to clean a dirty engine."
Old 09-29-2004 | 04:41 AM
dkubricht's Avatar
why would it scare you? no difference then driving in the rain. like hitting those big *** puddles that spray the sidewalk with water.
Quick Reply: Product Review - Gunk Citrus Engine Brite
