remove side trim
Old 06-19-2007 | 03:13 PM
04sierracanada's Avatar
Default remove side trim
how do i remove the crome side trim on my 04 sierra
Old 06-19-2007 | 04:02 PM
redLS1rado's Avatar
Use a heat gun and peal it off or use fishing line and run it behind the molding. Do a search and you will find many posts
Old 06-19-2007 | 04:07 PM
greencountry05's Avatar
This is what I did on mine.........A heat gun, a body eraser disk that you put on a drill, and maybe some rubbing alcohol. Heat up the trim with the gun but be careful not to get too close to the paint or let it stay in one spot for too long or else it might mess up with the paint. Usually there will be some adhesive left over from where the strips were attached, that's where the eraser coems in. You can get the body eraser at parts stores and if they don't have one you can get them at the local paint and body shop. You attach it to the end of a drill, make sure you note what the rpms of the drill are and what the recommended rpms of the eraser are.....don't want to peel your paint off do you? After you take the remaining adhesive off you might want to wipe the area down with alcohol or something to get the stickiness off. OR..........you could just take it to someone who does detail work and have them take the sticky crap off and buff your truck. Did I forget anything? If I did, someone please fill this guy in.......
Old 06-19-2007 | 04:55 PM
BlackLM7's Avatar
My side molding came off VERY easy. I slowly pulled the molding while I sprayed some WD-40 to help soften the glue and breakdown the adhesive. All of the glue stuck to the molding. No need to use an eraser wheel or rubbing alcohol. I didn't even use a heat gun. When I was done, I went over the area with some wax. My truck was only 6 months old when I pulled the molding and I think the glue was still soft. Maybe that's why I had no problems.
Old 06-19-2007 | 08:35 PM
ZDEN's Avatar
i always just peel it off then use a towel to with my thumb in it to rub off any thats left. after that just clean up the residue with sticker shock or something.
Old 06-19-2007 | 08:38 PM
perrco's Avatar
just dont go ripe it off like i did after my reck it makes it look worse. lol.
Old 06-20-2007 | 12:25 AM
i think my truck was in an crash or somthing the driver door trim has a hard black silicone on it they must have used it to hold it on any ideas to get it off
thanks for all the feed back its realy helpfull. ill post befor and after picks
thanks
zblee
63
06-10-2023 02:25 PM
GXPJAY
02-13-2022 09:15 AM
Ketis
07-23-2015 01:37 PM
banker099
07-04-2015 06:50 PM
