Replacement Seat Foam
Old 03-01-2011 | 10:18 PM
Atomic's Avatar
I have a gauge for that
Default Replacement Seat Foam
Does anyone know a good place to get replacement foam for these seats? And do you know if there is any difference between the 99-02 and the 03-07 foam?
Old 03-01-2011 | 10:38 PM
1bad2k's Avatar
I think the foam is the same. have you tried gmpartsdirect?
Old 03-01-2011 | 10:54 PM
Atomic's Avatar
Hmm, good call
Old 03-01-2011 | 11:04 PM
Atomic's Avatar
Passenger side:
Seat - 12473282 - $90
Back - 88941599? -$60
Head -
Driver Side:
Seat - 12473281 - $123
Back - 88941594? - $90
Head -
Cant find any info on the back sections. The numbers above for the back sections are for 03+, the seat section is 99-02.
Old 03-01-2011 | 11:26 PM
Formerly 99-2door-08/30/2010
the 99-02 and 03+ foam are shaped a little bit different.
Old 03-02-2011 | 12:21 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Check with your local upholstery shop. They will have several different types of foam available. There are some areas of the stock seat foam (bolsters, etc) that can be cut down, and better foam glued down before the upholstery goes back on. The seat will feel entirely different, and more comfortable.
Old 03-02-2011 | 04:18 AM
TIM Z's Avatar
11 sec. Truck Mod
The 99-02 are different from 03- up.
Around a 100$ for a drivers bottom with my buds discount from the dealer.
Best bet is to try and find some used seats on craigslist for parts.
someotherguy
11-08-2017 06:46 PM
600 horses
09-10-2015 11:01 AM
BlackGMC
09-09-2015 01:43 PM
xerox17
09-05-2015 01:23 PM
the owl
09-04-2015 04:09 PM
Quick Reply: Replacement Seat Foam
