shaking
PT's Slowest Truck
Most common problem that causes a brake pulsation are rotors that have too much runout (warped), as mentioned above. Other items that may cause a brake pulsation are bad wheel bearings or severely worn steering components, but there should be other symptoms (noises, looseness in the steering) if that was the case
Are the wheels stock wheels or aftermarket? It could depend whether they are hub centric or lug centric. If they're lug centric, they will tend to wobble at higher speeds. You can get hub-centric rings for the wheels to correct this.
shaking
ultra 17x8 thunder#247/248 w/pirelli str,s ultra wants these rims back .thank you everybody for your help i live in shallotte n.c. its hard to deal with someone over the phone in cali.
black00chev
08-28-2015 03:39 AM
