So, i had to try it...(Plasti-dip)
Old 09-21-2011, 06:58 PM
The House is Rockin'
BLUES MAN's Avatar
Originally Posted by geoz3
ACE hardware has it in different colors, did mine in white, came out well.
wheres the pics buster...
Old 09-21-2011, 10:23 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
It looks like you were gonna just do the spokes, then ended up doing the whole wheel? Did it lift & peel when you were trying to remove the tape?
Old 09-21-2011, 10:30 PM
JoeGibbSilverado's Avatar
Gotta be careful on the tape lines, it will lift. I trimmed my headlight rings on my s10 with it. Im curious about the clear also, it should still peel, but i think it might blister.
Old 09-21-2011, 10:33 PM
Nuclear Endless's Avatar
Someone else in Johns thread said that you can't clear over it and still expect it to come off... the clear basically seals it down in my understanding.
And I think the safest way to tape it the one set of tape per coat, and peel while wet...
Old 09-21-2011, 10:34 PM
Blowndenalixl's Avatar
That would seem to be a great solution for those living in winter cities and not wanting to purchase winter tires and rims, but yet don't want their beautiful chrome rims pitted by salt, etc over the winter.
By the way, I like the "killed" look. Either way, agree those rims are killer.
Old 09-21-2011, 10:42 PM
1SICKhawk's Avatar
yeah i started with just the spokes it was to hard the peel where the spoke meets the lip of the wheel, it was a pita..
Old 09-21-2011, 11:03 PM
I guessed that would be the case, thanks for affirming that. Did you try to peel the tape while the PD was still wet, or after it had dried? Seems like it might work well if it was still wet.
Old 09-21-2011, 11:05 PM
I did mine while dry, no go. Gonna retry while its wet, thanks for that tip.
Old 09-21-2011, 11:23 PM
If it works, post a new thread, with pics.
Old 09-22-2011, 04:56 AM
1bad2k's Avatar
It may not be quite as easy to remove wiith clear over it, but I can tell you for sure it won't be permanent. Think about it, its designed to be removed easily, therefore it isn't a good base to begin with if you're looking for something permanent.
Like someone said before, it would be an ideal product for someone not wanting to buy winter rims. That's a good idea right there!
Quick Reply: So, i had to try it...(Plasti-dip)
