taking of the ram 1500 badges
I've seen a lot of rams without the ram 1500 badges on the doors. I think that looks great. How do they come off? Are they any bodywork, or do you simply remove them. Thanks for the help.
Just get some fishing line to saw between the badges and the body. Then clean up the left-over adhesive with an adhesive remover (Goo-gone, alcohol, etc.) of some sort. Try searching debadging on here; there are several people that've done it, mostly on GM's that I've seen but the Dodge decals should be pretty much the same.
Yea, makes it look alot smoother. I used a blow drier to heat up the adheasive a little and then some fishing line. Goo-Gone works good, just takes a little elbow grease. Luckely you Dodge huys dont have that door molding going all the way down the side of the truck!(I think). I had to do the 2 badges on the tailgate, the 1500 on the doors, and then the door molding from the front wheel to the rear wheel. It was an all day project. Good Luck.
SLOPONY
20
10-18-2016 06:05 AM
FlowmasterMufflers
07-09-2015 11:35 AM
