Tinting tail lights with Night shade. Questions
Old 01-25-2009, 12:05 PM
03chevyroyce's Avatar
i just used duplicolor
and wet sanded before i sprayed the clear
Old 01-25-2009, 12:06 PM
also, they aren't as dark as they look in the pictures, but that is 4 coats
Old 01-25-2009, 02:02 PM
whitegmc2002's Avatar
i would say ppg clear..
Old 01-26-2009, 01:15 PM
Terry Crews's Avatar
i took mine to a tinting place that does business through a body shop. the jus mix a little bit ov black with some clear and use a spray gun. its only $100 for all three lights. i used that spray night shade on my buddies cars and it turns out fin. not as good but worth it for the price. spray as many layers as you want on the light, depending on how dark you want them, but paint them all at the same time next to eachother so u can see that theyre even. an make sure u use a full can because the bottom of the cans paint tends to turn the lights gray.
Old 01-26-2009, 02:58 PM
dhpro's Avatar
This is a new one for me...pls clarify the process?
1. take off the light cover, spray it with 1+ coats of 1part blk/3 or 4parts clear - ON THE INSIDE?;
2. wet sand, then 2+ coats of clear...thats it?
What wud happen if u used a satin clear coat? Think it'll work on the fronts too?
I was lookin at this: http://www.xpel.com/products/headlight_protection.asp
Old 01-26-2009, 03:20 PM
Wearin' da big hat
00ChevyScott's Avatar
You paint the outside, not the inside.
Old 01-26-2009, 03:43 PM
dhpro's Avatar
Ahhhh...said the blind man!
Old 01-26-2009, 03:49 PM
hirdlej's Avatar
You guys with the dark tail lights, it looks gorgeous but don't you worry about people rear ending you from not seeing your lights?
Old 01-26-2009, 04:18 PM
JakeBrakeIH's Avatar
actually believe it or not, they are still pretty bright...i was skeptical on this so i did a medium shade if you will and my friend did dark and i wish i went dark also...
Old 01-26-2009, 04:23 PM
chevrolet all the way's Avatar
the ones i have seen actually shine like regular
Quick Reply: Tinting tail lights with Night shade. Questions
