Tire Size for 18's on a Sierra RCSB...
Old 07-08-2009, 09:12 PM
  #21
Sierra1320's Avatar
I hope the 285/50's tuck without sticking out too far. If not I'll just have to keep the two extra for spares for the rear and order 255/55's for the front if it absolutely comes down to it.
Old 07-10-2009, 03:39 PM
  #22
Sierra1320's Avatar
Anybody else think these wheels and tires will or will not tuck on my truck? Thanks guys for any imput! I know 285/50's will tuck, but it all depends on offset of the wheel. Like I said these wheels have a +20mm offset and they're 18"x9" Cragar 616C wheels.
Old 07-10-2009, 03:53 PM
  #23
dlt76028's Avatar
heres my titans with 285/50/18 and stock offset of +25mm. i dont think they would tuck.
Old 07-10-2009, 08:45 PM
  #24
Sierra1320's Avatar
I might have to put 255/55's up front with 285/50's out back. I'd like to keep the same tire size on all four corners so I can rotate them, but now I'm not so sure thats the case. I know 95brightteal's had 255/55's up front with 285/50's out back with a 3/4 drop and it looked absolutely beautiful! Anybody else have any suggestions on tire size?
Old 07-10-2009, 08:53 PM
  #25
GMCtrk's Avatar
285/50s are too short for my tastes, but I suppose if you're dropped they'll work. On a 9" rim I would go with the widest rears you can fit on it. The 305/45 sounds good.
Old 07-10-2009, 09:18 PM
  #26
Sierra1320's Avatar
I'm gonna do a 3/4 drop cause I want some rake to the truck and to give it a purposely mean look. I'd love to put 305's on the back, but the cost would be too much for me and I don't absolutely need the grip of a 305 right now. 255/55's up front and 285/50's on the rear is sounding tempting right now or just 285/50's on all four corners, but then Im wondering if the 285/50's would fit with the offset of the wheels. I'd consider 305/45's if I could find a good deal on a set of them.
Old 07-10-2009, 10:49 PM
  #27
95 bright teal's Avatar
If you do 285/50 all the way around just make sure under full compression you dont hit the fender. with my 265/60's i barely tucked the tread of the tire when compressed and it lightly rubbed the inner fender.
I dont think my 255/55 did, because they were 1.5" shorter.
I think you will be fine with 285/50 up front, just check your clearance
Old 07-11-2009, 03:42 PM
  #28
Sierra1320's Avatar
I'd like to do 285/50's all around, but what do you guys think would look meaner with a 3/4 drop?
-285/50's on all four corners
-255/55's up front....285/50's out back
-255/55's up front....305/45's out back
The truck is going to be daily driven so I need a tire that I can get some good mileage out of and I see that the 305/45's are only made my nitto. The truck is going to be black with chrome wheels and with the 3/4 drop it's going to have a fair amount of rake to it. Thanks Guys.
Old 07-22-2009, 02:25 PM
  #29
Registered User
jwelliott's Avatar
Default niche throttle wheels
Do you still have the rims? One of mine is cracked at the lug and they are soooo hard to find. Let me know! Thanks.
Originally Posted by lawson4450
mine are even and yes they are 255/55/18 toyos and the wheels will probably be for sale soon as soon as my new ones get painted, rims only i need the tires off of these wheels. they are niche throttle rims i have had them for about 9 yrs.
Old 07-22-2009, 03:59 PM
  #30
ap2002's Avatar
i would go with this
M/T also makes a 305/45/18, and are probably a more stickier tire...
Quick Reply: Tire Size for 18's on a Sierra RCSB...
