Tire Size for 18's on a Sierra RCSB...
#21
I hope the 285/50's tuck without sticking out too far. If not I'll just have to keep the two extra for spares for the rear and order 255/55's for the front if it absolutely comes down to it.
#22
Anybody else think these wheels and tires will or will not tuck on my truck? Thanks guys for any imput! I know 285/50's will tuck, but it all depends on offset of the wheel. Like I said these wheels have a +20mm offset and they're 18"x9" Cragar 616C wheels.
#24
I might have to put 255/55's up front with 285/50's out back. I'd like to keep the same tire size on all four corners so I can rotate them, but now I'm not so sure thats the case. I know 95brightteal's had 255/55's up front with 285/50's out back with a 3/4 drop and it looked absolutely beautiful! Anybody else have any suggestions on tire size?
#26
I'm gonna do a 3/4 drop cause I want some rake to the truck and to give it a purposely mean look. I'd love to put 305's on the back, but the cost would be too much for me and I don't absolutely need the grip of a 305 right now. 255/55's up front and 285/50's on the rear is sounding tempting right now or just 285/50's on all four corners, but then Im wondering if the 285/50's would fit with the offset of the wheels. I'd consider 305/45's if I could find a good deal on a set of them.
#27
If you do 285/50 all the way around just make sure under full compression you dont hit the fender. with my 265/60's i barely tucked the tread of the tire when compressed and it lightly rubbed the inner fender.
I dont think my 255/55 did, because they were 1.5" shorter.
I think you will be fine with 285/50 up front, just check your clearance
#28
I'd like to do 285/50's all around, but what do you guys think would look meaner with a 3/4 drop?
-285/50's on all four corners
-255/55's up front....285/50's out back
-255/55's up front....305/45's out back
The truck is going to be daily driven so I need a tire that I can get some good mileage out of and I see that the 305/45's are only made my nitto. The truck is going to be black with chrome wheels and with the 3/4 drop it's going to have a fair amount of rake to it. Thanks Guys.
#29
niche throttle wheels
Do you still have the rims? One of mine is cracked at the lug and they are soooo hard to find. Let me know! Thanks.
