tire size calculating
does anyone have a link to a good tire size calculator? if so PM me
or does anybody know the formula to convert metric tire sizes (275/40/R20 for example) to standard sizes for measurements (28.6" height, 10.8" width for example)
i googled for tire size calculators and could only find ones to find what size fit on current vehicle from stock tire size
wanting to see how wide of a street tire(22s) i can fit on the rear and get a front tire thats the same height
thanks in advance
need the converison for 295/35/R22 for now, but would like the formula for future use
EDIT: i know about the one from miata . net, but it doesnt give dimensions on width
thanks in advance
FormerVendor
thanks in advance
thanks in advance
Radius: 15.1"
Diameter: 30.1"
Circumference: 94.7"
Revs/Mile: 669
Originally Posted by DLH2006
Sidewall: 4.1"
Radius: 15.1"
Diameter: 30.1"
Revs/Mile: 669
Radius: 15.1"
Diameter: 30.1"
Revs/Mile: 669
someone posted a whiel back the actual formula to figure it i think it might have been silverbrick or someone replying to his post but i cant find it ANYWHERE
295/35 22
width/wall ratio rimsize
the first number is the width. divide first number by 25.4 to convert it to standard
width = 295/25.4
height is width x ratio then multiplied by 2 then add rim height
You really need to find the specs from the manufacturer. The width listed, 295, includes rim protectors. You alsoneed to consider the contact patch width.
lol on the silverbrick. I will not be a brick much longer. well, i will but much faster.
width = 295/25.4
Originally Posted by Silver-Dollar
295/35 22
width = 295/25.4
width = 295/25.4
this is who i was referring to as silverbrick
https://www.performancetrucks.net/fo...er.php?u=60969
Lamartian92
09-10-2015 09:27 PM
Lamartian92
08-21-2015 01:43 PM
luisalmighty09
08-20-2015 11:35 PM
