Two truck newbie questions.
I just bought a 2000 GMC sierra 4x4. Can anyone answer two questions for me?
One, what is the best brand of clear headlights/signals? I would prefer the crystal clear ones. But more importantly they need to NOT leak. The clear corners on my camaro leak like a **** and I have to keep getting new bulbs.
Two, What is the tallest/widest tire I can mount on stock rims at stock hight? I think I am going to run toyo or goodyear M/T's
Thanks.
Thanks.
well alot of the aftermarket lights are not to good, maybe you should look into some ones used denali headlights, other wise i found that the tyc company is a decent aftermaket headlight company. and the tires, i think that you can do 33inch or 275's without rubbing on a stock haight truck. someone will correct me ir im wrong.
I've got TYC crystal signals, they do pretty good except when water is applied directly to them like a car wash or something then they will fog up for a few days. over all I am pleased with em. The only reason my lights burn out is because i run the xenon white lights (witch are actually more blue) from wal-mart in both my running and turnig lights.
Just make sure you keep em clean cause they look like **** when they are dirty.
Originally Posted by Z06 DREAMING
nice
Thanks
The best brand of clear headlights is GMC...i.e., clear the ones you have by removing the amber reflectors. This is a total pain in the ***, but at least they don't leak. Here's how you do it:
http://www.fullsizechevy.com/forums/...ad.php?t=95438
As far as tires, most people have good luck with 285/70R17 or 285/75R16.
to Endo.
Its really easy to clear the stock GMC headlights, just make sure you use a good silicone sealant and they shouldn't fog up. Mine have been done for 3 years and have never fogged up. TYC is the best I know of for the corners as well; I don't know of too many companies that make the crystal clear corners. I just got some cheapies from procarparts and they've been pretty good but it looks like they've yellowed a bit over time, but what can you expect for 20 bucks.
