Valance Wings
#51
Wile most are smart enough to know the wing doesn't make any downforce nor is it needed in this case. There are atleast a few people ignorant enough to think so. I was directly answering one of them not trying to insult all the people with enough brains.
#53
Spoilers/Air Dams
So what does all this have to do with your street car and its fashionable spoiler tacked to the trunk? Aerodynamics still has a role in street cars and you don’t have to be going at 200 mph for it to concern you. The frontal area will produce drag, the air collecting under the car will produce lift, the shape of the rear facing parts will create turbulence and additional drag as well.
So what can you do about it? Street cars are designed for utility as well as looks. People look at cars primarily as a statement of how they wish to be perceived. They will rationalize sacrifices in fuel economy or carrying capacity for the sake of image or a desire for a certain level of performance.
During the 1980′s the Pontiac Firebird and the Chevrolet Camaro often competed for which car could produce the lowest Cd or drag coefficient. The bodies were very similar with the only real difference being the changes in the front and rear bumper cover, but the Firebird always seemed to squeak by with a slightly lower Cd. The numbers were derived from wind tunnel testing at the same facility. Later it was revealed that the Pontiac team would remove the rear view mirrors from the doors to get their number.
If you want to get the most out of your car’s aerodynamics you can keep it clean and waxed. Then you can change out the springs to produce a more raked body where the front end is closer to the ground than the rear. That will help to produce a low pressure area under the car.
You can further enhance this by installing an air dam on the front keeping it as close to the ground as you find practical.
Then you can clean up the underside of the car by covering or removing items that produce turbulence.
Don’t forget to allow air flow to facilitate cooling of the engine compartment.
A spoiler in the rear will provide additional downforce or you can opt for a wing to get less drag and more downforce by putting it up in cleaner air.
Those wide tires you added will produce better traction, but may cost you a 30-35% penalty in drag, so see if you can make the wheel wells smaller.
Slip Through: A Primer to Car Aerodynamics
written by streetsidemechanic | May 6, 2011
We’ve all seen them. Some of us own them. Honda Civics, Nissan Sentras, and Toyota Corollas with gigantic, GT-style wings bolted onto their trunk lids. Some of us think they look cool, and some of us find them ridiculous. But despite how they look, what do they do? Is there a function? Do they actually make cars faster?
Yes and no. To clear things up in the realm of spoilers and splitters, wings and diffusers, we’ve poured a thin concrete foundation for the study of car aerodynamics. Keep in mind that we are not physicists, and that actual physicists have studied fluid movement for thousands of years. Aristotle was among them. We’re just a bunch of grease monkeys.
We start with some basic principles of aerodynamics. Air always moves from an area of high pressure to an area of low pressure. When it piles up, it seeks to release itself and pushes against whatever object is containing it. This is how a hydraulic jack works.
And that’s why the front of your car produces drag. As you speed down the highway, the front of your car pushes against the air, creating an area of high pressure. In response, the air pushes back. For a more visual example, picture a snow plow struggling through a January blizzard.
Now, you’re thinking that drag is only what occurs behind a car. That’s a bit of a misnomer, but it happens there, too. The areas behind your rear windshield and trunk produce negative air pressure which creates a vacuum effect. As air seeks to enter these areas, it curls over your roof and trunk, creating turbulence, which causes resistance.
Drag zones are like taxes. You never want to have any of them, but you always will, to some degree. Conversely, downforce is your friend, especially in racing. Downforce is created when, at higher speeds, the air pushes your car down toward the ground. This improves traction and stability, and is eagerly sought among performance car designers.
Unfortunately, since most cars on the road are roughly shaped like the cross section of an airplane wing, they oppose downforce. Yes, your car can actually generate lift. But you won’t take off, since your car is too heavy, and since there is some natural downforce to be had. Air piles up against your grille and windshield, and as it seeks an area of lower pressure, pushes down and back. The underside of your car can also produce downforce. Air is pulled out from under your car, which creates another area of negative pressure, pulling your car lower.
So with the science somewhat explained, what about those Civic wings? Do aerodynamic mods do any good?
Spoiler/Diffuser- These are the small fins you see on car trunk lids. Most of them are factory installed, and provide a clever way to break up the turbulence behind your car. They can reduce drag, making your ride faster and more efficient. You can find one on the back of a Toyota Corolla S.
Wing- A rear wing is large and swooping, commonly called a spoiler, but something very different. It is not meant to reduce drag, but to create downforce. Since it is essentially an inverted airplane wing, it uses the same principles airplanes use to lift off, to shove your car against the pavement. That’s why rear wings are essentially useless on front-wheel-drive cars. At speed, a wing pushes the rear wheels down, which reduces pressure on the front wheels, killing traction. For a car with wings on the front and back, see Walter Rohrl’s AWD 1987 Audi Quattro S1, which he used to set records at the Pike’s Peak International Hill Climb.
Bug Shield*- It seems odd among this expensive, carbon fiber race equipment, but some say that the bug shields you see on trucks every day can actually reduce drag and improve overall aerodynamics. A bug shield can help prevent air from getting caught in the gap between your hood and windshield, reducing turbulence.
Air Dam- An air dam blocks air from getting under your car, which improves the vacuum there. This, as mentioned above, will increase downforce and can help reduce drag, as well. Many modern body kits include air dams for this purpose.
Splitter- This is a plate that runs horizontal to the ground in front of your car. It works like an air dam, preventing air from making its way to the underbody. It also increases the surface area of the underside of your car, which means a better vacuum. The bigger the splitter, the better. The 2012 Ford Mustang Boss 302 Laguna Seca Edition is a good production example. Unfortunately, most states have outlawed splitters over a certain size, citing pedestrian safety.
Lowering- Another way to improve underbody downforce is to simply lower your car. The less air that can get under your car, the more downforce you’ll generate. That’s why tarmac race cars seem to barely clear the pavement. For examples of this, see any of the cars of the modern British Touring Car Championship.
Racing machines, from F1 screamers to the Diesel mills at La Mans to dirt kicking rally cars, are designed to generate the least amount of drag and the most downforce possible. Adding similar mods to your car can do the same, but only under the right conditions. And aero modding won’t just improve your speed. It will also boost your fuel efficiency, since your car won’t have to work as hard to slip through the air.
#54
What was the point of that last post? It said nothing about ugly, bent peices of plastic. The wings you installed aren't doing anything but making you happy. There is a 1 in a million chance your wings helped areodynamics but there is a 999,999 in a million probability that it made no differance or a negative one on performance.
If you like the wings then let the thread die and be happy. Nice and simple. Only other post you need to make would be results in a wind tunnel. Short of that you aren't going to convince anyone they look good and without results the rest of us "know" they didn't help.
#55
#56
The House is Rockin'
