Water leak wtf!!!!!
Water leak wtf!!!!!
I have a leak some where in my tahoe and i have no clue as to where its coming from. for the longest time i have noticed that when it rains the driver side floor board gets wet. i thoght it was from wet shoes and what not cause i found a small hole in my floor mat. well recently i got a new set of floor mats with no holes and the problem is still there.
i made sure all the holes in the fire wall (wire harnessess) were closed up nicely. i pulled the carpet and padding back. then dried it all up and left the carpet up so i could see the floor. i ran a water hose over the truck and got nothing. but last night it rained its *** off, so i checked it this morning and there is a puddle. sooo wtf what do i need to check now?
when i bought the truck it had a horrible wind noise. come to find out it was the windshield molding pieces. that was after they did a bunch of other crap that didn't fix it and i figured out it was the molding with some tape. so they replaced the moldings.
i thought it was the wires through the fire wall but its had the leak before then.
now that i think about it i've had the amp and sub in there this whole time. and my fuse to the amp under the hood is pretty badly corroded for some reason. its mounted behind the fuse panel by the fender. i wonder if water it coming through gap between hood and fender onto the fuse and following the wire right into the firewall.
ok so sun roof is leak free. some how water is getting into the kick panel channel. i'll try to explain. if you pull back the kick panel plastic there is a black plastic piece behind it. the hood pop handle is kinda over it. if you pull that back you can see into the body channel itself. that was filled with water. from what i could tell, when that gets full it spills out and then fills up the floor board and the under the skid plate by the seat. i pulled that up and the wire harness and plastic holder piece. there i found the metal retainer is rusted to ****. so now my truck has cancer.
there should be a gasket/weatherstrip between the front fender and the door. check and see if that gasket is still there and whether or not it will still seal. you might have to remove your fender to get to what i'm talking about.
