water spots
Old 03-04-2010, 09:31 PM
Registered User
joky123's Avatar
a beautiful place is the spot with water
________________________________________________
weeds seasons 1-5 dvd boxset
Old 03-05-2010, 11:59 AM
The House is Rockin'
BLUES MAN's Avatar
i had real bad water spots, vinegar wouldnt remove them. had take a razor blade to them, just be careful not to scratch the glass.
Old 03-05-2010, 01:35 PM
In the 12's??????
chevythunder06's Avatar
Very fine steel wool worked on my glass, just keep the window very wet with your favorite window cleaner.
Old 03-05-2010, 01:52 PM
Badboy464's Avatar
the acid that you clean wheels with is what my local detail shop uses on waterspots on paint. I don't see why it wouldn't work on windows you only want it on there a few seconds or you can do some damage.
Old 03-05-2010, 07:56 PM
BuiltNotBought's Avatar
Buy some steel wool usally comes in packs of 3 grades. Use the lightest one you can find. Do little at a time or ull scratch the hell outta ur window. Dont use the wool on ur mirrors at all. Ok so grab ur lite gauge wool and some chrome polish. Tape the black trim around the window off so u dont scratch it or get any polish in there. Apply the polish to the area ur working on. And use the whole like a applicater pad ( use little pressure). Going around the area in a swirling motion. Its very important to always keep the area wet. Once the polish dries wipe it off and repeat till the whole window is done. After the window is done go back over it with wax to seal it from any more water spots. Also get some latix gloves at AZ for ez clean up.
Old 03-05-2010, 08:02 PM
skolman91's Avatar
Originally Posted by chevytruck
Rubbing alcohol, give that a try. DO NOT get it on the paint.
rubbing alcohol will not hurt paint by the way, it will fade or stain rubber and plastics i believe tho..
Old 03-05-2010, 09:00 PM
Where's the Beef?
viciousknid's Avatar
Thumbs down
Am I the only one that Noticed this?
Old 03-05-2010, 10:20 PM
BLUES MAN's Avatar
^ yeah i saw it, whats the point of responding to him, he's off puffin the magic dragon
Old 03-05-2010, 10:23 PM
Wearin' da big hat
00ChevyScott's Avatar
Kill that spammin SOB
Skip Fix
22
07-09-2016 07:08 PM
Jordan927
11-10-2015 02:47 AM
turbo6c3
10-05-2015 06:11 PM
MOBBN
09-22-2015 08:07 PM
kmcn47
09-17-2015 01:12 AM
Quick Reply: water spots
