what drop am i on?
c notch for sure, any lower than 4" and you need a notch IMO...and i would definately go with a flit kit...
and justin for sure! haha there's about two more ft of those pilings showing now lol and the only reason its that full is cause they're feeding it water out of eagle mtn!
formerly 2low4nd (11-08-2011)
I have a c notch. Ill prob just flip and add the overload leaf spring back into the pack and run a 2" drop arm or shackle added to the mix.
With a 22" wheel on a 275/35r22 should be around 29 tall...
Im trying to obtain this look wheel and drop wise.
La seisita HD truck, its sick!
do you have any idea how hard it is to drive a truck that low lol i had about 2" of clearance on my truck and i pretty much got sick of it being that low because of how hard it was to drive
I think he is closer to 6/8. But a 5/7 i can handle. Its not a DD. It sits in the garage 90% of the time so, im thinking i can live with it. My truck only comes out on sat or sunday afternoons or when i track it.
Baltimore Whore
Most def, they look sick as hell. trust me if could drive my truck everyday with a 5-7 I would.. but it is not happening here.. Notice the bottom of his rockers, beat to ****.. LOL Low is great, but it begins to become a pita. I have already been pulled over for swerving to avoid bumps and all in the road, I am not even that low..
Ok after looking at the truck again, just noticed it had a Lowering Shackle & Hanger Kit. So that would be a 4" drop in rear. Im guessing then it has 2-3" drop springs in front. So from here im going to install 3" belltech drop leafsprings to add a total drop of 7" in the rear. Then in the front im going to install a 3" drop spindle in front to have a total of 5-6" of drop in front. Im even thinking of running a 2" spindle up front the truck has a small amount of rake right n ow and that would eliminate that.
I've read and heard that flip kits ride the best... and they're cheap too.
As far as the front, if you're wanting to do it right, go with something besides those springs if at all possible before getting the spindles etc. on
hopefully gs7793 will chime in again for you, he knows his lowering stuff pretty well..
