what engine degreaser/underhood cleaner?
I wash my truck almost weekly (interior, exterior and underhood) for a little over 3 yrs now and haven't ever had a problem with anything electrical. Ive used several different cleaners also. Simple green and a brush have worked best for me. I've also wondered about Adams engine cleaner. Just remember after you wash underhood that you start your truck so that way the engine heat dries everything.
im sure it leaves a sticky residue that attracts dirt?
maybe the picture at the beginning of the second post in this^ thread will change your mind, maybe not. just throwing it out there
If they (knock sensors) have already been sealed off good then sure i wouldnt hesitate as much to be getting the manifold wet..
I use Autoglym Engine Cleaner & Degreaser to clean everything. Use a detailing brush to loosen up the tough grime. Hose off and dry w compressor.
Then I use Sonus Trim & Motor Kote over everything to make it look like new.
I tin foil off most electrical connections though...just to be safe.
FormerVendor
There is some concern about water in the engine bay, but not as much as some people think. Cover up any open element filters, battery terminals, and possibly your alternator using plastic bags or foil to keep them dry. Obviously if you've done any mods and spliced electrical connections making sure those are water tight is important, but box stock from the factory most any newer truck or car isn't gonna have an issue with some water in there. If you do opt to use a pressure washer (I don't recommend it) then make sure you use a very broad fan tip and keep it a good distance away from everything - not because of the water but the pressure potentially forcing water somewhere it shouldn't be.
Heres a video I threw together to explain the process I use, not the gospel, but a process I've used for over 13 years of detailing and have yet to have anything go wrong.
http://www.youtube.com/watch?v=JdHX_wPUKZI
I always run my motor as soon as i pull out of the bay and let it idle as I dry my truck and I have had very few problems with water, just dont sit there and spray directly over your intake and over your coil packs/alternator. the rest should be pretty well out of the way for you to worry about. I have found that after you degrease your motor if you go through detail your engine bay with tire wet or anything similar that it keeps all the hoses nice and moist and do not tend to dry out and crack. Also the oil base makes the engine look amazing and then when it gets dirty all you have to do is hose it off again since the oil keeps any greas and grit from actually sticking to the motor! I have a couple pics of my enginge that I just did the week of xmas, pics came out a little blurry but you will get the point, if you want to go look at my alblum.
Good Luck!
