#71
My exhaust guy always uses the male/female v band. It makes it stupid easy for r and r.
Check out my old thread. They are expensive but seem well worth it.
https://www.performancetrucks.net/fo...tested-522108/
Nice welder. I love me some Dynasty haha.
I used to use the flat v-bands, made my own male/female versions by sticking the tubing through one side roughly a 1/16th and on the opposite side I'd keep it off the edge a 1/16th +. That was before they started making the male/female designs.
I love the m/f versions now, makes assembly that much easier.
Nice write up Choda
Nice write up Choda
That makes total sense. Wish the kit mfg would have thought of that! I read tales of V-bands like they cure cancer but after my first experience with them, I'm honestly not that impressed with flat mating. Almost impossible to get it lined up right in a tight spot. Looking forward to better results with these.
Also got myself a little toy to give the middle finger to those lock nuts on the clamps:
The following users liked this post:
Mercier (12-29-2017)
#74
If you want to switch anything up try looking into marman flanges, very nice alternative to the V band. I cut all mine off and went to make/famale and don’t have leaks. When I decide to change up my exhaust I’m welding in marman flanges
#75
Get V band clamps from Race Parts Solutions and ALWAYS use anti-seize on them! Especially the cheap ones cuz they use a ss nut on a ss bolt and similar metals like that will gul really easy. You'll notice a good quality v band clamp will have a ss bolt and a zinc coated steel crimp style self locking nut. There is a reason for that.
If there is room in side the v band ring, cut a short piece of tube to fit inside the ring and go in both halves. This will keep it aligned.
The following 2 users liked this post by kbracing96:
Mercier (12-29-2017),
ZR1 DREAMING (08-19-2019)
#76
I like the idea of the short piece of tube. I think I might even weld the flanges on a bit "short" to allow for a short piece in the middle.
Thanks for the ideas!
#78
If you can look at the lock but used, the nylon ones melt and loosen up over time, I go to the local hardware store and swap them out for the metal style lock nuts. I too used anti seize during assembly
#80
OK so these plug wires have really kicked my butt. Once I put the studs in, the ceramic boot wires interfered with the studs enough that I couldn't get nuts on. Also the Taylors come with the wire set almost at the end of the ceramic boot and that left me scratching my head for a bit as clearance on a couple was terrible whereas the dang Accels(same boot as shown before!) fit before all the wire ends came off.. Once I figured those two bits out, I saw a path forward.
Studs on the first and last manifold holes and bolts in the middle. No interference with the ceramic boots and still something to keep that a$$hole gasket aligned. Basically a semi-permanent rendition of the classic headless(longer) bolt in the ends to hold the gasket up. But this will hold the gasket and the manifold with turbo attached if/when needed(like when futzing with plug wires). Next round I'll probably go with much shorter studs in the middle holes but probably keep the longer studs in the ends.
I had to make sure I got the end of the wire in just the right place where I maximized space yet had enough wire in there to still allow the connector to pop over the end of the plug. These wires are short but I think perhaps just right. They give a good, positive click on the plug and into the coil and don't seem to want to creep off so I'm rolling with it. I would probably be zip-tying longer wires out of the way anyway.
Now to put it back together, test fire for proper ignition, then get back to the exhaust.
