Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
4l85 IN NEW 2WD SS'S?
Old 06-21-2005, 11:01 PM
jdg
14 Second Truck Club
jdg's Avatar
Originally Posted by OUT2WIN
I wonder if GM's sight made a typo? And truck trend says 4L85E
Thanks JDG
I don't think they did as this is coming straight from their online order guide. I noticed not to long ago they started referring to the M32 as an HD. Also the transmission on the new Trailblazer SS is an M70 (4L70E). This same transmission is going to be on the "VortecMax Performance Package" offered for the 2006 Silverado extended cab 4X4 and the new short bed crew cab 4X4.
VortecMax Performance Pack, includes (LQ9) Engine, Vortec high-output 6000 V8 and door badge that reads "Vortec Max", (M70) Transmission, 4-speed automatic, super duty, (GT5) Rear axle, 4.10 ratio, (G80) Differential, locking, heavy-duty, rear, (ZX3) Suspension Package, Ride-Control, (NP8) Transfer case, electronic Autotrac, (KC4) Cooling, external engine oil cooler, (KNP) Cooling, external transmission oil cooler, auxiliary, and (Z82) Trailering equipment, heavy-duty
1 - Requires CK15753 or CK15543 Models. (QJM) or (QJP) Tires must be ordered. (P25) Wheels must be ordered. Option content within this package may not be substituted or deleted. - Not available with (Z71) Suspension Package, Off-Road.
Old 06-21-2005, 11:34 PM
James B.'s Avatar
M30 = 4L60-E
M32 = 4L65-E
M33 = 4L60-E for hybrid (electric oil pump, etc.)
M70 = 4L70-E
MT1 = 4L80-E
MN8 = 4L85-E
M74 = Allison 1000
Old 06-22-2005, 06:24 PM
Leroy_454's Avatar
Ok, I just read the article in Truck Trend Magazine about the 2005 RWD SS. It does indeed say 4L85E and lists its correct gear ratios. Can anyone confirm if this is correct or a mistake???
Old 06-22-2005, 07:34 PM
JeRM82's Avatar
Its nice to know that I'm not crazy.....ha ha....someone else saw it too...
Old 06-22-2005, 09:49 PM
Just because you were right doesn't mean you're not crazy....
-Chuck
'03 DSG Lightning *sold*
'05 GMC Sierra WT 4.8L
Old 09-15-2005, 04:32 PM
83 Chevy's Avatar
I am skeptical of several bits of data in that article. I think the trans should have been a 4L65-E instead of a 4L85-E. If the person putting the data together thought it was an '85, then it makes sense that they would find and list the ratios for that trans.
The tire size is listed as 245/75R20 which would have a diameter of 35.4 inches, which is a significant increase over the 31.9 inch diameter 275/55R20 tires that were previously used. Again I think this is a typo.
The axle ratio is listed as 4.10, but an article on the internet said Chevy changed the ratio to 3.73 in the 2WD SS.
So, someone has a 2WD SS and can verify this stuff. How 'bout it?
Mike
Old 09-15-2005, 07:24 PM
Post
Mike
The 2wd SS does come with 3.73 gears.
It's hardly any different than the VHO trucks other than the body kit.
Jim
Old 09-15-2005, 07:48 PM
PT's Slowest Truck
budhayes3's Avatar
What's a 4L70E? Is it like a stronger 60/65E, or a weaker 80/85E ? This is getting confusing...
Old 09-15-2005, 07:58 PM
11 Second Truck Club
2bseen's Avatar
It should have had a 80 in it.
Old 09-16-2005, 06:16 AM
dkubricht's Avatar
im confused as well
Quick Reply: 4l85 IN NEW 2WD SS'S?
