Found an RST
#52
Thanks man. Let me know how it goes. I had a W4me tune on my 00 silverado 4.8 auto and it made a hell of a difference. I wonder myself about the difference with the 5 speed.
Who is doing your tune? I'm close enough to Blackbear that when I'm ready I'll just drive down. Want to get all the looks stuff finished first
#55
i want to know more about these mail order tunes~~~
i was always told bad things about them but it was for my wifes modded LS1 car, they always said you needed a full tune due to the changes....
well my question is , i want one for my truck, basically a stock 04 GMC RST, dont know if they changed any computer stuff or not, but i do tow a trailer with 2 mowers on it during the summer, but yet i want to get the truck to run a bit better~via..mail order tune, i quess being a stock tune it would be easier to tweek it,......who has had one , who did it , and was is the pros and cons,.....i do planning on keeping the truck stock untill next year whem im doing full exhaust redo,.(headers,y-pipe, o2 delete, and cat delete) which i know it will need tuned then,...just looking for a little more power untill then..
thanks in advance, Boog
#56
My understanding is that until you go with heads, cam, forced induction, and/or N02 a mail order will suit a person fine. Pretty much all they are doing is adding or pulling timing and adding or leaning air/fuel, and for automatics they can change shift points and firmness and modify torque management.
I'm sure a tune can be more dialed in on a dyno, but for the extra money additional gains would be negligible imo.
#58
My use of mail order is a bit misleading...I found a local guy with the help of these forums that does what he calls a pcm edit for 70 bucks. A couple of others from here vouched for him, and I figure for the money I can't go wrong...my thinking is that I don't need a full dyno tune with the stock'ish setup. He says his pcm edit is the equivalent of a mail order.
#60
It's in MD about 60 miles away from my place. Should have it in the morning. Replacement wing got here today. 04 tails hopefully in the morning too or Monday. Unfortunally I don't have tags for it.
