Joe Gibbs Modifications
Zippy on SilveradoSS.com started a thread like this for us and I've found it to be very helpful. Please create a post with your mods in the following format, and update as needed.
Year:
your truck / audio / cosmetics:
engine size: (stock, cubic inches, liters, etc.)
camshaft: (stock or xxxx lift, duration, brand)
cylinder heads: (stock or xxxx brand or hand ported/also valve train choices)
pullies: (stock or other)
intake system: (stock intake, blower (type, boost level, etc...), cold air intake, etc.)
exhaust system: (from manifolds headers all the way back)
pcm modification: (stock, edit, hp tuners, custom tuned, etc. )
spark: (wires, plugs, gap, etc.)
Year:
Year:2005
your truck / audio / cosmetics:stock
engine size: stock, 5.3l (non superchared)
camshaft: stock
cylinder heads: stock
pullies: ASP udp.
intake system: Volant cold air intake.
exhaust system: stock manifolds with Corsa cat back.
pcm modification: HP Tuners.
spark: wires.
__________________
camshaft: stock
pullies: ASP udp.
spark: wires.
__________________
Year:2005
engine size: 5.3
camshaft: stock
pullies: stock
intake system:magna charger supercharger, airaid intake
exhaust system: corsa cat back
pcm modification: stock
spark: grantelli wires with ngk plugs
suspension: hotchkis tvs system
engine size: 5.3
camshaft: stock
pullies: stock
04 Joe Gibbs Silverado regular cab
Year:
engine size: 5.3
camshaft: stock
pullies: stock
intake system: Volant cold air intake, 7lbs of boost, stock intake, Magnuson blower
exhaust system: SPINTECH exhaust with turn downs , X-Pipe, no cats, stock manifolds
pcm modification: NELSON PERFORMANCE custom tune
spark: Stock
suspension: 4/6 drop with Hotchkis 2' front springs and 4' rear leaf springs, 2' drop spindles, 2' Mcgaughy's drop spindles.
engine size: 5.3
camshaft: stock
pullies: stock
spark: Stock
Year: 2004
your truck / audio / cosmetics: Joe gibbs scsb #80/ 2 kicker solo 10's, mtx 7402, infinity reference 520 4 channel, alpine cd3000 deck, full infinty reference highs./ 4/2 drop for nowand aftermarket centerlines.
engine size: (stock)
camshaft: (Stock)
cylinder heads: (Stock)
pullies: (3.10" )
intake system: (stock intake, blower (radix IC, 10psi), K&N cold air)
exhaust system: (edelbrock shorties, stock y pipe, corsa cat back)
pcm modification: (stock superchips tweaked with predator)
spark: (msd wires, bosh platinum 2 plugs, stock gap)
camshaft: (Stock)
pullies: (3.10" )
2005 rcsb joe gibbs
Year:2005
your truck / audio / cosmetics: 2005 Joe gibbs rcsb 5 speed / factory / joe gibbs hurst short throw shifter joe gibbs rims, joe gibbs gauges, joe gibbs badges
engine size: stock 4.8
camshaft: Custom Ground comp cam, plus com springs
pullies: know supercharger "turbo"
intake system:custom
exhaust system: 4" from turbo back through 4" flowmaster
pcm modification: custom tune
spark:ngk tr's
spark:ngk tr's
Year:2005 RBSB black, originally 4.8 5 speed with JGP sport trim package.
your truck / audio / cosmetics:Stock JGP, if it doesn't make it go faster you don't need it.
engine size: 370ci
camshaft: Custom ground 223/219 .578 .550 114lsa
cylinder heads: L92's
pullies: N/A
intake system: L92 carb style intake manifold modified for efi, GTS-76 Turbo with FMIC and meth inj.
exhaust system: Custom single turbo set up with 3"QTP cut-out on downpipe and stock JGP Corsa cat-back
pcm modification: Custom HP Tuners full speed density tune with 3 bar map
spark: NGK TR6 plugs @ .035" gap and Crane Fireball wires
Tranny: T56 6 speed from F-body and Textralia Exoskel dual disc clutch.
Rear end: 3.73's with Detroit Tru-track and Caltrac bars
engine size: 370ci
pullies: N/A
2005 JGP 4x4 Tahoe
Year : 2005 Tahoe Gibs #0075 4x4
your truck / audio / cosmetics : stock JGP , factory navigation , only shine is the JGP wheels w/nitto 420s , baer 14" brakes .
engine : 5.3
camshaft : stock
cyl heads : stock
pullies : Pulley Boys 3"
intake : JGP Magnuson 10 psi , snow meth. inj.
exhaust : stock JGP corsa cat back
pcm mods : 2 bar efi live
tranny : Finnish line level 5 4L65E W/ vac mod and 10.5" vigilante converter
rear end : 4:10s w/ eaton posi
engine : 5.3
camshaft : stock
cyl heads : stock
2004 Joe Gibbs Silverado
Year: 2004
Joe Gibbs reg. cab, 3/5 drop, foose speedster 20's, RST spoiler, debadged, projection headlights, smoked tails.
engine size: Supercharged 5.3L auto
camshaft: stock
pullies: stock 3.6
intake system: stock
exhaust system: Pacesetter shorties with corsa cat back exhaust
pcm modification: custom tuned
spark: TR6 plugs
camshaft: stock
pullies: stock 3.6
spark: TR6 plugs
Year:2004
your truck / audio / cosmetics: JGP
engine size: Stock 5.3
camshaft: Stock
cylinder heads: Stock
intake system: Stock
pulley: Stock
exhaust system: Headers and Corsa cat-back
pcm modification: Stock
spark: Stock
The truck ran 8.93 @ 80 in the 1/8th mile has corvette servos and lowered 1" in rear
camshaft: Stock
pulley: Stock
spark: Stock
