Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Regency RST Complete Write-Up Info
Old 06-10-2009, 05:37 PM
  #1121
formerly 2004RST (changed 11/19/2012)
OneQwikSS's Avatar
Originally Posted by RED04REGENCYRST
yeah, jersey is a hike for me. and the truck should be doing alot more than what it is. i can already feel a difference in the 4.88 gears, by a good amount. my iat's that day didnt get under 109* even going down the track. can you say heat soak?
i need to get a set of dr's and smaller wheels to run at the track. cuz running on the 20's is hurtin me bad i know. ill have to get ahold of some 17" steelies to run, cuz with the brakes i cant run anything smaller and clear the brakes.
i plan on testing it again when it quits raining every other day round here and see what i can get as she sits right now.
look for a set of stockers on craigslist i found a set of 4 with tires for like 200 just my .02
Old 06-11-2009, 09:49 AM
  #1122
1quickRST's Avatar
That just sucks man. Its always something when you start modifying.....
Old 06-11-2009, 11:00 AM
  #1123
RED04REGENCYRST's Avatar
thats what i plan on doing once i have the funds.
Old 06-12-2009, 09:20 PM
  #1124
5speedsilverado's Avatar
hey red04regencyrst, you could still make your truck look good with the steelies, this is what i did to the stock one that came on mine
Old 06-13-2009, 10:34 AM
  #1125
OneQwikSS's Avatar
need to get some drop on that truck ^^
Old 06-13-2009, 06:57 PM
  #1126
i plan on it, i was going to do the 1.3/3 like the rst's sit, i really like that stance
Old 06-13-2009, 07:44 PM
  #1127
OneQwikSS's Avatar
don't do it...go 2/4 as a RST owner i know i want mine lower you get a MUCH better stance out of a full 2/4
Old 06-13-2009, 08:34 PM
  #1128
i like the *** end high look it has to it, but mine sits too high in the rear
Old 06-17-2009, 09:32 PM
  #1129
quick question regarding the t56, if you just do that swap do you have to reprogram the computer? or is it just plug and play? btw no cruse control for me
Old 06-18-2009, 06:00 AM
  #1130
the shifter locatoin is about 12" back from the hole that the 5-speed comes through and you would need a 26 spline clutch setup. other than that, yeah the vss connector is the same but you have to retune for the different speedo gear inside the t-56, and the reverse light plug is the same.
i talked to a gm mechanic friend of mine and he said that he thought the cruise control settings were in the body module and you would need a tech2 or something to go in there and reprogram that. just an fyi.
you will need to step up the gear in the rear end too or be doomed to gas mileage and no go out of the whole. i finally stepped up to 4.88 gears after breaking the 4.56s and i effin love them. the truck gets up and hauls ***.
on another note i just got ahold of some 02 16" stockers that im gonna run some drs on and get some new track times. just gotta get the cash for the drs.
Quick Reply: Regency RST Complete Write-Up Info
