Regency RST Complete Write-Up Info
#1131
i have just found that i had to completely redo my high/low octane and base idle timeing tables and the truck rips out of the stop lights now. i have to feather the clutch to keep from breaking her loose. plus i have reduced my knock retard and got rid of the burst knock all together.
i dont know if you can tune your truck or if someone else did but i figured id just throught that out there.
#1132
your mostly stock right?
#1133
formerly 2004RST (changed 11/19/2012)
off topic has anyone bought anything from that regency auto parts yet? if money wasn't so fu$@#d up right now i would have already...but yeah it is...
#1134
the shifter locatoin is about 12" back from the hole that the 5-speed comes through and you would need a 26 spline clutch setup. other than that, yeah the vss connector is the same but you have to retune for the different speedo gear inside the t-56, and the reverse light plug is the same.
i talked to a gm mechanic friend of mine and he said that he thought the cruise control settings were in the body module and you would need a tech2 or something to go in there and reprogram that. just an fyi.
you will need to step up the gear in the rear end too or be doomed to gas mileage and no go out of the whole. i finally stepped up to 4.88 gears after breaking the 4.56s and i effin love them. the truck gets up and hauls ***.
different topic, i made a 0-60 run of my truck, what do you think? i screwed up on the take off. and didn't run it for all it has, i only hit 3/4 throttle
http://www.youtube.com/watch?v=6BDjqXjPudo
#1135
Yeah, mostly stock. Just got the cam, the blower, a stg3 clutch and fans with the full exhaust package. I debated changin all the timing and stuff but i dont think thats where my problem lies. I just simply cant hook worth a . I may end up doin a T56 in the long run, cuz 3rd gear truck just seems to hit a brick wall til about 75mph... then she rips all the way to redline...
not yet but from talkin with them they dont seem to be too bad in the customer service department, but of course they are still tryin to get my money.
#1138
My son and I showed our 2006 Jon Moss RST this past weekend at the GM Carlisle show in Penn. We won first place in our class, Chevy Silverado. Everything was grouped together. We were the only 2 wheel drive truck in the class.
plumber 1
plumber 1
#1139
plumber 1
plumber 1
