Regency RST Complete Write-Up Info
#1522
Ty to everyone for all your input!!!!
I got the nelson tune in today, and its awesome! No problems, didnt need to relearn/reset anything, and since im a big need for speed guy (hey arent we all?) I espically like being able to go 125+ over the limited 100... LOL!!! (p.s. thats the frist thing that was tested)... they upped my rev rpm from 5500 to 6000. and i can tell theres a little more response in the pedal from the TM taken away...
I definitally want to put 4.10's in the rear's but should i put a bigger rear end in it before? and since its a light duty truck do i need to worry about snapping driveshafts and such?
Im also pricing 5.3 engines too...
heres my all out goal...
-5.3 engine swap
-transfer the cold air intake
-cam it/new springs/rockers etc...
-supercharger
-Ford 9in rear end with 4.10 gears
-upgraded suspension
-4L60E tranny swap
-retuned
-NOS (but thats the very last thing, even if)
Thats where I want this truck to go... but having a wife and a kid puts a HUGE slow pace to this, lol...
-5.3 engine swap
-supercharger
-4L60E tranny swap
-retuned
#1523
also, Red u said front mounted Turbo... anyone know any good sites where i may find one at for the 4.8?
also also, having trouble picking better cam... dont know much about them, so which u think be better... the 54-535-11 or the 54-450-11? Both are part numbers through summitracing.com
#1524
I had mine tuned by Blackbear last week. I've also tested the 100+. Got to 108 and let out of it. The top RPM limit is set to 6300. I really haven't tested much on it. I can say it drives a lot smoother, the idle is a lot better and lower. The MPG is 19.5 all highway.
It's pretuned for LTs that I need to put on.
#1525
#1527
formerly 1fstrst (11/25/2010)
Name: Rob Melcher / Foose04
Year: 2004
Make: GMC
Model: Sirria
Body: rcsb
Engine: Stock 4.8
Tranny: NV3500
Drive: 2WD
Mods: Cam, MP70 turbo (67mm,P-trim, .81a/r T4)
Correction: SAE
Dyno: DynoJet
Date 6/8/2010
HP: 528
Torque: 528
You can get some good performance from the 4.8. Look at foose04 stats. A 4.8 with a turbo making good #'s
__________________
2004 GMC RST: 528HP/528TQ
Year: 2004
Make: GMC
Model: Sirria
Body: rcsb
Engine: Stock 4.8
Tranny: NV3500
Drive: 2WD
Correction: SAE
Dyno: DynoJet
Date 6/8/2010
HP: 528
Torque: 528
__________________
#1528
I currently have a stock ds in there now, but a highspeed balanced aluminum one is on the way in as we speak along with the tubs and all that good stuff.
As for the engine stuff, i second the skip on the 5.3 notions. If you're going to shell out money and all that time to swap in a motor, you may as well get a 6.0 as even an lq4 can be usually had for the same or slightly more than a 5.3 (we're talkin wrecking yards here)
I also don't think i recommend a 4l60. If ur planning on boost, idk if even a level 4 or 5 can hang? Of course I dont know much about automatics, but I think a 4l80 with upgraded internals may be more fitting? Maybe some others that are more knowledgable on this can chime in.
#1530
another question from the illiterate engine dummy...
I saw in a youtube video (http://www.youtube.com/watch?v=q5iLNAUTbH4) that this guy put a Ls2 intake on his 4.8L... Is that simply a bolt on or if u change the intake to an Ls2 will u need to replace anything else?
