Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Regency RST Complete Write-Up Info
Old 07-18-2010, 08:10 AM
  #1621
formerly 2004RST (changed 11/19/2012)
OneQwikSS's Avatar
Originally Posted by Stroked-DSM
If people are making 500+whp on a stock 4.8 with an under hood turbo, why would you do a complete build on a motor with plans of only making 500-600whp? Doesn't really make sense to me.
New heads are not necessary for 500 whp. You can mill, or port some GM heads and they will be more than enough. You don't need to build a stroker for that whp goal either.
I'm looking to make about 400-450 whp with a cammed, stock block, bolt on + spray 4.8...
for me i'm looking for constant power with less chance of break (that's why i'm using the go big or go home method)....and i'm not looking for 500 - 600.....realistically i should be between 850 - 1100 depending on my tune & spray...
Old 07-18-2010, 10:30 AM
  #1622
jadaven's Avatar
400 - 450 I'll be happy.
Old 07-18-2010, 11:55 AM
  #1623
Silver05Rst's Avatar
WORD! but more towards 500 for me
Old 07-19-2010, 03:06 AM
  #1624
ok, now im starting to get uber pissed... I ordered my cam over a month ago it said it would be here by the 30th... then it said it wouldnt be here till the 31st... now its saying the 3rd of august...
DOES IT REALLY TAKE THAT FRICKEN LONG TO MAKE 1 DANG CAMSHAFT?!?!?!?!?!?!? (serious question, aside from the yelling)
Old 07-19-2010, 06:15 AM
  #1625
jadaven's Avatar
I've got an 02 ZO6 cam I can sell you. Have it to you in about 3 days
Old 07-20-2010, 12:55 AM
  #1626
lol, naaaaa thats ok. im good lol
I will wait for mine, i already paid for it, but ty tho!!!
Old 07-20-2010, 06:07 AM
  #1627
RED04REGENCYRST's Avatar
silver - is it a custom grind? if not get your money back and go somewhere else.
Old 07-20-2010, 11:18 PM
  #1628
I dont know... this is the exact cam i got... http://www.summitracing.com/parts/EDL-2215/
If its not a custom grind where's the best place to look?
Also... When i got my tune through nelson perf. i had a Jet stage 1 chip on my stock PCM. When i swapped them out i still put the chip on the performance PCM. Should I have done that? Or should i of taken it off when putting the Nelson PCM in?
Old 07-22-2010, 05:46 AM
  #1629
its not a custom grind, edlbrock has someone mass produce the cam and then sells them as an off the shelf cam. the reason your waiting so long is there probably isnt enough orders to get the manufacture to grind that series. id say get my money back and find one through a pro shop. you might even be able to get someone to grind a cam with those specs for close to the same price.
how is your pcm running as performance chip? is it a handheld unit that flashes the pcm?
Old 07-22-2010, 06:31 PM
  #1630
http://www.jetchip.com/JET_Chips_Modules.asp
Check out that site. I got the Stage 1 cause i dont need to put 91 octane in it nor do i have the 180 thermos. it plugs into the pcm between the PCM and the truck harness. No handheld, just plug in and go.
Is a mass air flow sensor worth the $$$ to get?
Quick Reply: Regency RST Complete Write-Up Info
