Regency RST Complete Write-Up Info
#1641
Had a guy that builds drag cars and chassis do it for me. Has over $10k in parts (Fab9, Cage, Suspension, Brakes, etc), with labor and all came to just over 18k. I was going to do it all myself, but decided I'd rather have someone that has been doin this pretty much their whole life do it, and I couldn't be happier. Looks like it came from the factory that way, hah.
Hey guys any input on these Intakes???
http://www.fuelairspark.com/0/FS/Intake/Default.aspx
http://www.compperformancegroupstore...y_Code=GMTruck
#1642
on stock motor, it isnt gonna give you hardly any gains. if you were big cube (408+) or fi you would see big gains from that. not worth the cost imo.
im running a tbss intake/tb on mine and saw about a 15hp/15lbtq at the rear wheels with no other changes on my 6.0, its a cheap upgrade, but i helps.
#1647
youll get large rpm spikes when you step on the gas while already rollling, without tire spin.
i tought the rt was meant for trucks and you had to order the port that would fit your setup. cuz if im not badly fooled the r is the 102mm car intake. if you try to run the car intake youll have to change all the accessories on the front of the motor.
i was wrong, lol. see below
http://www.cpgnation.com/forum/fast-...fold-2707.html
#1649
So if u get the rt then u dont need to change any of ur setup, like the water pump for example??? I understand u would probably have to buy the 102mm throttle body tho or else the 90mm...
#1650
Hey what is everyone running for shocks. Mine have 80k on them so they are going out. I'm ordering a set of Belltech streets today.
On another note got my efans. should be installing them mid next week. Waiting on Harness right now.
