Regency RST Complete Write-Up Info
#201
thanks boog. thats all forth gear, and only 5800rpm, toppin out at 140mph. lol
the tuner told me that i was pullin 102% on my injectors at the time, and my intake was maxed onflow at 5800rpm. so i need to upgrade my intake and tb, and injectors. man do i have the bug bad lol.
#205
Hey guys, Ive also been following this thread from the beginning and Im finally stopping in to say whats up!
My trucks in my sig.. my bumpers actually at the painters right now getting black on it. I couldnt stand the chrome center piece it stuck out like a sore thumb
#206
On mine they took like a inch hole saw and cut threw the door panel and then drilled a 1/4 inch hole in the door frame. The shity thing about this is that you have to take the leather accent piece off first and when you do the plastic push in clip deals break off and nobody and i mine nobody sell them that long. I finally talk to my uncle and gm and he said the only thing that comes close to that is in the crew cab gm trucks had there used to put the headliner in. and it's a royal bitch to get them put back on. the leather accents are just glued to a piece of plastic and you have to peel the leather off far enough to put the new clips in and then use some adhesive to reattach the leather to the plastic. it's pretty shitty the way they did it i can't believe they used a hole saw to attach it. they put about seven holes in door panel.
#207
here is the last vid and the dyno sheets
Strap Came Loose
Almost There
Final numbers sheet
Baseline sheet
After installing the NGK TR6's and adding alittle timing sheet
Strap Came Loose
Almost There
Final numbers sheet
Baseline sheet
#208
Regency 04
The leather trim panel is what I couldn't figure out. Thank you for the help. Maybe no Dynamat on the doors. I put Dynamat on the roof, rear of the cab by the back window, and down the sides of the cab. Thanks again.
Plumber 1
Plumber 1
