Silverado SS rear end swap...
I think KYSilverado or someone has done this swap.
Yes it's pretty much a straight bolt in. I'm not sure about the yolk mating up to the driveshaft but the spring perches are the same distance and everything else will work. Basically short answer is that it will work with minimal to no modification.
Look for SS sittin above it.
Acc. to Fireman 31, it comes w/. 4.10s, so I read that as no different 10 bolt than yours other than gear ratio. Same ring gear, same G80- I'd pass unless it's the 14, but it's your $. A set of 4.10s isn't worth effort to me of a rear to rear swap. Unless that's what u want or u get out the door for a song. My .02.
Last edited by fastnblu; 07-17-2009 at 08:10 PM. Reason: Could be worth it if bought on cheap to get the gears.
The 10 bolt is a POS, if you can find a 14 bolt with a 6 lug setup then grab it, but it will not be easy to find......most will be an 8 lug out of 3/4 ton trucks...
yea well im not ready for ne thing yet but i am getting a 6.0 soon....soo i know ima need to upgrade the rear end at one piont too. i def want it to hold up but im not going to the track every weeknd either just want it to be good on the streets! but one thing i will not do is keep my one tire fire! i want to two lines not one lol
