Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Build Up of the 14 Bolt Semi-Floating Axle
Old 02-16-2007, 08:54 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
SO I guess you found a way to adapt the factory brakes to the drum flanges? Is that the same kind of 14 bolt I have? I know mine was out of a 93 van.
Old 02-16-2007, 10:30 PM
axisT6's Avatar
Yes, I can get the factory brakes to work.
Old 02-20-2007, 10:23 PM
axisT6's Avatar
More pics...
Axle Installed:
Old 02-20-2007, 10:25 PM
axisT6's Avatar
New flanges welded on to bolt the disk brake backing plates to:
Also notice the bling U-bolt flip which I recommend to everyone as the way the u-bolts are oriented from the factory promote corrosion on the bottom of the axle tubes.
Old 02-20-2007, 10:27 PM
axisT6's Avatar
Here she is all finished:
Also, here is a shot of the new drive shaft that got installed as well. It is a 2 piece with a heavy duty carrier bearing and 1350 U-joints. This shaft was made by Gilbert at Driveshafts Inc. in Houston. I HIGHLY recommend him.
Old 02-21-2007, 11:49 PM
11 Second Truck Club
JJ_TURBO's Avatar
Nice Job, I will consider you when I built mine.
JJ
Old 02-22-2007, 05:46 PM
axisT6's Avatar
JJ
10-4
Old 02-22-2007, 08:40 PM
Banned
litreddevil's Avatar
Nice Work
Old 02-22-2007, 08:51 PM
bluecajun5.3's Avatar
damn skippy.
good job!
5.3Okasai
03-09-2022 01:07 PM
USMCvet0311
08-14-2015 10:28 PM
vipergtrdj
08-06-2015 10:19 PM
Dezert1500
07-30-2015 02:51 PM
iregret
07-27-2015 10:31 PM
Quick Reply: Build Up of the 14 Bolt Semi-Floating Axle
