Build Up of the 14 Bolt Semi-Floating Axle
Here she is all finished:
Also, here is a shot of the new drive shaft that got installed as well. It is a 2 piece with a heavy duty carrier bearing and 1350 U-joints. This shaft was made by Gilbert at Driveshafts Inc. in Houston. I HIGHLY recommend him.
New flanges welded on to bolt the disk brake backing plates to:
Also notice the bling U-bolt flip which I recommend to everyone as the way the u-bolts are oriented from the factory promote corrosion on the bottom of the axle tubes.
Dezert1500
07-30-2015 02:51 PM
