I know I'm a coonass but.....
Sexy Party Mod
IF you are billy badass at welding and can make aluminum vaccum tight it would be light. Probably more expensive but badass. I would stick to a big *** stainless unit myself.
And talking about anulus, and vacuum too. Hmmmmm
I would try to get ahold of some 3/16-1/4" stainless steel so there is no pitting....and stainless looks soooo pretty when the correct amount of heat is applied whilest "walking the cup." Its gonna be a heavy sumbitch so plan accordingly. Make a 2 boxes without tops then space it with angle or channel. Dont seal those welds. You will need some pearlite insulation within anulus as well.
Anybody got a Tig Welder i can borrow????
Sexy Party Mod
Wonder if some thick gauge SS would work? We have tons of it at work that gets trashed....
Yea itll work. Make sure you put a fair amount of braces in it if it is thinner. You just need to have it leek detected once you get it sealed. Its a bitch. They actually pull a vacuum on the anulus, hook up a Leak Detector (LD) and spray helium on the outside of the tank. If it leaks the helium(which is a very small/simple molecule) will be detected by the LD. If there is the slightest pin hole the tiny He molecule will get sucked in by the vacuum. Make sure you actually fuse the metal while walking the cup and dont dip the tungsten. If you do, grind it out and start over. Weld with stainless filler and use a clean grinding wheel and tungsten.
Quit hjacking my thread phucker
Sexy Party Mod
Mkay ******. Nonnie, let us take this to PM so Matt doesnt get butthurt Blah Blah Blah. My Happy Aggie *** drove over to BR to steal a Matts Ice...Happy Now?
Naw....MATH OWNZ JOOO!!!!1!!1
