Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
OK!!?? Nitrogen talk..
Old 08-02-2006, 06:47 PM
nonnieselman's Avatar
Default OK!!?? Nitrogen talk..
haha 1-1.5mpg increase with just nitrogen aired tires?? OK!!??
http://news.yahoo.com/s/ap/20060731/...trogen_tires_1
By DAVID SHARP, Associated Press Writer
Mon Jul 31, 2:22 PM ET
TOPSHAM, Maine - Many motorists seeking to improve their mileage as gas prices soar this summer are examining everything — right down to the air in their tires. And for a growing number, plain old air isn't good enough.
ADVERTISEMENT
George Bourque of Fairfield is one of those who's driving around on tires filled with pure nitrogen, the same stuff that NASCAR racers use.
Bourque, an engineer, said he has seen a 1 to 1.5 mile-per-gallon increase since he began filling his tires with nitrogen, which is touted as maintaining tire pressure longer and resisting heat buildup on hot summer days.
"I analyze everything," he said.
Nitrogen has been used for years in the tires of race cars, large commercial trucks, aircraft and even the space shuttle.
But it is finding its way into the mainstream at a growing number of tire dealers — including Costco Wholesale Corp.
Nationwide, fewer than 10 percent of tire dealers offer nitrogen, but the number is growing, said Bob Ulrich, editor of Modern Tire Dealer magazine in Akron, Ohio. Most dealers charge $2 to $5 per tire for the nitrogen fill-up, he said. The dealers generally offer free lifetime refills.
Bourque got his tires — filled with nitrogen — in Waterville, Maine at Tire Warehouse, which has 50 tire dealerships across New England. The nitrogen was part of an installation package when Bourque bought a set of tires.
Skeptics will question how much can be gained by filling tires with pure nitrogen when the air we breathe is 78 percent nitrogen.
The differences are subtle, but important, said Steve McGrath, Tire Warehouse's vice president of marketing in Keene, N.H.
Nitrogen molecules are bigger than oxygen molecules, so nitrogen seeps out more slowly from tires than air; nitrogen resists heat buildup better than air, which contains moisture; and nitrogen reduces oxidation, which can damage the tire from the inside out, proponents say. Nitrogen is an inert gas, so there are no safety or environmental issues.
Those advantages are important in vehicles equipped with tire pressure monitoring systems, which are sensitive to changes in tire pressure, McGrath said.
With or without nitrogen, proper inflation is the key to improving gas mileage. Motorists can improve gas mileage by 3.3 percent simply by keeping their tires properly inflated, according to the U.S. Department of Energy.
In the real world, though, only 1 in 5 motorists check tire pressure regularly, according to the Rubber Manufacturers Association. Nitrogen, therefore, could have an advantage for those who don't check their tire pressure regularly.
The National Highway Traffic Safety Administration has no opinion on nitrogen, but it does encourage motorists to keep their tires properly inflated, both for safety and to boost gas mileage, said spokesman Rae Tyson. Severely underinflated tires are dangerous, especially for sport utility vehicles and light trucks, Tyson noted.
Tire experts at Consumers Union, publisher of Consumer Reports magazine, neither endorse nor object to the use of nitrogen in tires.
"Nitrogen is certainly safe to use in tires, and theoretically it does offer some benefits," spokesman Douglas Love said from Yonkers, N.Y.
For Bourque, his tire pressure remains constant — 40 pounds for his fully loaded truck — even on hot days when tire pressure normally fluctuates.
His gas mileage was about 19 mpg when he purchased his five-cylinder 2005 Chevrolet Colorado. Now, with the engine broken in and new tires filled with nitrogen, he gets 20.5 to 22 mpg depending on whether he runs the air conditioner, he said.
For tire dealers, the nitrogen generator and associated equipment typically runs between $3,000 and $12,000, Ulrich said.
Marty Mailhot, manager of the Tire Warehouse in Topsham, said the idea is catching on with consumers, who are purchasing nitrogen for tires for cars, trucks, motor homes and lawn tractors. He has even tried it on footballs and inflatable tubes pulled behind boats.
He has a retort for those who pooh-pooh the notion of paying for nitrogen when there's plenty of free air for the taking.
"I say, 'Why are you drinking that bottled water when there's a pond out back?'" he said
Old 08-02-2006, 06:55 PM
Sexy Party Mod
FarmerBeau's Avatar
We have nitrogen at my shop and i plan on using it. The thing is, compressed air expands and contracts with varying temperatures. Nitrogen is stable.
2nd fastest 5.3 ECSB
trever1t's Avatar
I think what he's trying to say is that with constant tire pressure better gas milage results.
with Fully broke in engine and tires fully inflated, he gained 1-1.5mpg. Believable.
Old 08-02-2006, 07:00 PM
i just think its kindof weird to gain 1-1.5mpg with just puttin nitrogen in your tires?? maybe its worth it...i guess ill have to try it... we also have alot of nitrogen at work, so ill just have to see what happens..
Old 08-02-2006, 07:03 PM
trever1t's Avatar
I doubt you'd see that kind of gain. They were comparing a brand new Colorado before and after break-in which also had N filled tires.
Old 08-02-2006, 07:17 PM
well, i dont see how he knew that the N helped him, considering the breakin period..
Old 08-02-2006, 08:00 PM
Truck addict
goshawk23's Avatar
stick it in your tires and see what happens. nothing wrong with trying an experiment. i would like it simply for the fact that i don't have to check the tire pressure as often since it doesn't flucuate
Old 08-02-2006, 08:03 PM
SSlow 4.8's Avatar
shops around here are charging 5 bucks a tire... idk if that is fair or not. I dont care that much so i probably wont do it... but the guy at tire barn explained it very thorughly, made sense.. they've been using it in aviation for years
Old 08-02-2006, 08:04 PM
haha, i hear ya goshawk.. im goin try it this weekend if i haven enough time..
i noticed that my gas mileage dropped pretty quick to 15mpg, cleaned my K&N airfilter and now im back up to ~19mpg
Old 08-02-2006, 08:15 PM
Truck addict
goshawk23's Avatar
my filter needs cleaning. i don't have a K&N. i have a afe. i still use the k&n stuff on it to clean it.
Quick Reply: OK!!?? Nitrogen talk..
