Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
One Serious Axle Build!!!!!
Old 11-09-2007, 11:37 PM
axisT6's Avatar
Default One Serious Axle Build!!!!!
Alright, I was contacted by Lord Aries to do a 14 Bolt FF build for his Avalanche. The build is to go as follows:
1. Remove ALL factory 4 link bracketry from the current 10 bolt, and transplant them to the 14 Bolt FF.
2. Install 4.56 gears with a Detroit Locker.
3. Rebuild the 14 Bolt Hubs.
4. Install Disk Brakes.
5. Pressure wash, wire wheel, prime, and paint axle.
The axle will also have a 1350 U-bolt style yoke.
Here are some pics of the bare axle:
Old 11-09-2007, 11:42 PM
axisT6's Avatar
This axle came from a 1978 Van, has 1.5" shaft measurements at the splines, is 70" wide, and has a 10.5" Ring Gear. The tubes are 3-3/8" Dia. with .5" wall thickness. This axle will weigh 450 lbs. when done. What the truck may loose in additional weight, it will gain in traction and strength. Did I mention that this particular Avvy has a Turbo and Nitrous??
Old 11-10-2007, 09:46 AM
Yogi Bear's Avatar
That is one stout looking axle. Must have been a really big van! Ought to handle the Av really well. Good luck!
Old 11-10-2007, 09:52 AM
dirt track racer 81's Avatar
ive one worked on few avalanches but the ones i looked at were not leaf spring..it was a 4 link of some kind
Old 11-10-2007, 12:19 PM
axisT6's Avatar
Read item #1 from the first post.
Old 11-10-2007, 12:20 PM
axisT6's Avatar
Yeah, it was actually an Ambulance. However, all van 14 bolts are 70" wide.
Old 11-10-2007, 01:00 PM
optikalilution's Avatar
lol i roasted one on one of our ambulances at work last night, anyone want it.....the brakes locked up at about 85mph, SHATTERED ONE AXLE, broke both u joints, messed up the ring gear bad enough its no longer round, and caught fire!!!! lol i was putting out the fire with an extinguisher and telling my patient "everything is ok ma'm, im also a fireman"......LMAO what a day, by boss told me the repair estimate is already 4K
Old 11-10-2007, 01:26 PM
Tootall's Avatar
you know that this is going to lead to a matching front axle !
Old 11-10-2007, 04:22 PM
my reading skills aint that good..good luck man..
Old 11-10-2007, 05:14 PM
Lord Aries's Avatar
SWEET!!!! I can't wait to get this bad boy under my truck!!! I got the 10 bolt out today and will be shipping it to axisT6 on Monday...
Quick Reply: One Serious Axle Build!!!!!
