Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
replacement 918s ???
Old 10-23-2007, 03:37 PM
Tootall's Avatar
Default replacement 918s ???
https://ls1tech.com/forums/showthread.php?t=803298
anyone else get on this?
bad batch No.
1) 49253
2) 049045
3) 49826
4) 050808
5) 051791
from LS1GTO
Originally Posted by bergenfelter
I spoke with my contact at Comp today, Chris Mays. If you have a spring batch number that is numerically less than 054168 you have the potential to have a bad set of springs. If you have a batch that is below this number, contact Chris Mays at Comp at 901-795-2400 extension 505. I just received my new springs next day air.
John.
P.S. Mods, you may want to make this sticky for a while...
https://ls1tech.com/forums/showthread.php?t=728254
it is VERY difficult (if not impossible) for them to remedy any problems there might be with a spring by reading about it on the internet! So please, call CompCams at 800.999.0853 (that's their toll free tech line), and tell them you've got broken spring(s) and want to know what to do with them! Their customer service is second to none and they want to speak to you! Again, the only way they can fix a problem that might exist is to deal directly with the customer with the springs!!!
Old 10-23-2007, 03:42 PM
truckmann's Avatar
Hmmm nice find... I'll have to check into that since I have a used set of 918's in a box waiting to be installed.
Just found some additional info on this...http://www.ls1gto.com/forums/showthread.php?p=3272880
Old 10-23-2007, 04:12 PM
Just checked my new heads that came in yesterday ant that's what they have.
Glad I checked. I was going to order the crane springs but I think I will go ahead and use these.
Old 10-23-2007, 04:57 PM
joshua022's Avatar
Will they send you some, so you can take yours off and send them back? Its my daily driver and I can't have it down, then I can't get to work.
Old 10-23-2007, 06:01 PM
TouchOfEvil04's Avatar
Anybody got a number? I just pulled mine off and one was broke. This was only after 17k miles on a .551 lift too. Very unhappy with that.
Old 10-23-2007, 06:12 PM
joshua022's Avatar
batch #049253 is the bad batch
Old 10-23-2007, 06:25 PM
truckmann's Avatar
There are several bad batch no.'s from what I have read and they are supposedly replacing all of them upon request. I read they are sending them out next day air with a return shipping label included to send the old ones back within 20 days.
Old 10-23-2007, 11:46 PM
Tribe Shaman
PappyDan's Avatar
i got a set sitting off to the side for my new build.
i dont have the box and i did not buy them from comp.
can i swap mine out to, they have the blue strip.
Old 10-24-2007, 11:08 AM
Colby 04's Avatar
I have a call into Comp Cams about mine
I have a batch number that is supposedly affected. I'll let you guys know how it works out.
Old 10-24-2007, 11:18 AM
Hunt&Fisherator
silver-mod-o's Avatar
I'm calling right now.
Quick Reply: replacement 918s ???
