Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Times from HRP
Old 10-31-2006, 04:39 PM
Blue5.3's Avatar
Default Times from HRP
Ok back in July in the heat of summer I ran a best of
2.14
8.90 @ 80.46
13.86 @ 98.56
Sunday I made four runs
1st Pulled in off the road went through tech and had a friend ride with me on the first run.
2.32
9.35 @ 79.03
14.36 @ 97.05
2nd Like it runs on the street
2.22
9.09 @ 80.75
14.03 @ 98.31
3rd Took the tailgate off.
2.23
9.15 @ 80.15
14.12 @ 97.58
4th
2.23
9.12 @ 80.41
14.07 @ 97.98
When I ran the 13.86 I had the 26" ET streets and it was almost 90 degrees I think. Sunday it was 64 degrees and I was on street tires. Did not feel like I was spinning off the line. Does the sound about right? Are the taller tires killing me that bad?
Old 10-31-2006, 04:43 PM
$thatguy$'s Avatar
maybe so cause the smaller ones drop the gear ratio
Old 10-31-2006, 05:13 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I would be willing to bet you were spinning a little bit. I didnt think I was spinning in 4hi but I went back and saw dark blakc marks on the road. Stock stall?
Old 10-31-2006, 05:27 PM
Blue5.3's Avatar
Yep stock stall.
Old 10-31-2006, 06:31 PM
v8
17,16,15,14,13,12,11 Drvr
yep the weight and tire mass was killing your times, don't ever go to the track without the slicks again lol ahahhhahahhaa
should be comeing through beaumont on sat. about 12 noon, keep an eye open on
I-10 for a red/black ford pulling a white/pewter truck eheehheee
Old 10-31-2006, 07:51 PM
Blue5.3's Avatar
I will be in the woods when you are going through Beaumont.
Old 10-31-2006, 09:25 PM
Banned
litreddevil's Avatar
puss
but yes 2 reason for the time difference is the height of the tire and you were spinning both can make a huge difference
Old 10-31-2006, 11:28 PM
TXsilverado's Avatar
it was cool outside but it was also humid as ****. humidity kills da. my strongest run was at full weight driving straight to the line after driving to the track. the later it got the slower my mph got(even though i lost weight and shortbelted). at full weight i trapped higher MPH in the 1/8 than with the gate removed, subs removed and shortbelted. the time was worse, but the mph was up without any spin. my 60' was off 1/10 too but thats probably due to the new 18's and wider tires which are probably lighter than my factory 17's were)
my best of the night was 14.35 @ 94.26 on a hotlap. my best ever was 13.80 @ 96.98 but that was also on slicks, no back seat, no passenger seat, no trailer hitch, and AWESOME weather. im trappin the same mph in the 1/8 as i did with the slicks and all that so i figure my trucks stronger, the weather just wasnt with us... all i added was the rollpan and ASP pulley.
kevin, do you feel like doing your DA magic and tellin us what it was on sunday night? 8:00 - 10:00
Old 11-01-2006, 05:47 PM
v8
-1100'
Old 11-01-2006, 06:00 PM
damn, thats good isnt it? ok, nm...my trucks a pile o ****
Quick Reply: Times from HRP
