trouble code P0300
trouble code P0300
OK For the last two months or so my check engine light has been coming on and off. While the light was on i took it to autozone so that they could tell me what the problem was. They hooked up their little computer gagdet and they told me it was a multiple random misfire (P0300), i think that was the code. Any ways, the light will come on about every two or three weeks and stays on for a day or two then it turns off. Ive checked the spark plugs and the wires and they are fine. I checked them with a ohm meter. I have a wheatley tune for 93 octane, catless, and a bullet muffler, rebuilt tranny with a vig 3200. what could be my problem ??????
BTW i posted in this somewhere else but got no responses !
Originally Posted by Grumpy4.8
did you have any lean codes to go with the 300???
Originally Posted by v8
your misfire codes need to be set higher or your injectors need to be cleaned.
Banned
1 Post
your miss fire settings may need to be set higher.
the only thing is if he has no cam that should not have to been done that is what causes miss fires
do you feel it miss fire
