Tundra vs. Colby 04
What all do you have done to your truck, and how well did he hang with you?
What was funny...this was an older couple
'07 Toyota Tundra Specs
4.7L DOHC 32V i-FORCE V8 with Variable Valve Timing with Intelligence (VVT-i)
271 Horsepower @ 5400 rpm
313 Torque @ 3400 rpm (lb.-ft.)
Cast-iron block with aluminum heads. Acoustically Controlled Induction System (ACIS) – dual stage intake manifold
Compression ratio: 10.0:1
4.300 rear axle ratio, (4.100 rear axle ratio on 4.7L models)
Recommended fuel: 87 octane or higher
5.7L DOHC 32V i-FORCE V8 with Dual Independent Variable Valve Timing with Intelligence (VVT-i)
381 Horsepower @ 5600 rpm
401 Torque @ 3600 rpm (lb.-ft.)
Aluminum block with aluminum heads. Acoustically Controlled Induction System (ACIS) – dual stage intake manifold
Compression ratio: 10.2:1
4.300 rear axle ratio (4.100 rear axle ratio on 4.7L models)
I'd make sure I had a fast truck before thinking of messin' with those.
