Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
07-13 Silverado / Sierra 1500 Bolt-on Single Turbo Kit Available For Preorder
Old 12-19-2018, 12:29 PM
Former Vendor
Strictly Performance's Avatar
Default 07-13 Silverado / Sierra 1500 Bolt-on Single Turbo Kit Available For Preorder
Introducing our Strictly Performance Truck Turbo Kit for the 2007-2013 GM Trucks!
Purpose built with the LS-enthusiast in mind, this turbo setup offers an effective solution for today's popular forced induction setups on the GM LS Truck platform. This kit is handbuilt here in the USA, not overseas and then brought over here to be
re-labeled. You'll be hardpressed to find a higher quality kit available on the market for these trucks. This bolt-on kit is engineered to give you outstanding performance while maintaining your vehicle's factory-like fitment and reliability. We utilize all name brand components, no cheap knockoff products.
There is no cutting or drilling your truck to install this kit. It is 100% reversible. This kit is designed to keep A/C and has heat shielding included ensuring proper function of the A/C system.
This kit is ideal for street trucks as well as off-road applications as the intercooler sits up behind the grille instead of below the bumper.
This Turbo kit is capable of producing over 800WHP. Our test truck gained 180whp at just 6 PSI producing 400whp with just this turbo kit, 65lb injectors, and an in-tank
Walbro pump. That was on a completely stock engine, with the factory DOD camshaft and a stock 4L60 transmission! This kit utilizes the LS-Series Precision 7675 Turbocharger Rated to support 1,150HP. Featuring a 76mm cast compressor wheel and a 75mm turbine wheel, this turbocharger is an excellent match for the widely-popular LS family of engines.
PLEASE READ:
Your truck will need to be upgraded to support this turbo kit and horsepower. The stock fuel injectors and fuel pump are not going to support the fuel needed to turbocharge your truck. Most trucks with stock engines will be making around 400rwhp at 6psi of boost. The LS engine platforms are strong and we have seen customers make over 600hp on a stock motor. However, by installing this product onto your vehicle, you assume all risk and liability associated with its use. If you would like to purchase a motor capable of supporting 600hp+ checkout our Boost Prep 5.3 LS-Series Long Blocks or our custom build forged internal engines.
Contact us if you would like to be put on our waitlist. Shipping date is expected to be in January.
Link to the kit on our website
(269)350-9055
Sales@StrictlyPerformance.Parts
www.strictlyperformance.parts
Precision Turbo LS-Series PT 7675 Turbocharger (HP Rating: 1150)
Strictly Performance Stainless Steel Tubular Exhaust Manifolds, Crossover pipe, and 4'' Downpipe
Precision 46mm
V-band wastegate
Tial 50mm Blow off valve
Treadstone TR1245 4.5" Intercooler (Rated at 1000hp)
Strictly Performance Aluminum Intake and Intercooler piping with MAF provision
Vibrant Performance couplers and t-bolt clamps (black)
Custom laser cut and formed intercooler brackets and hardware
Complete Custom AN oil feed/drain kit
Billet LS Oil feed adapter
LS Timing Cover Oil return
LS3/LS7 MAF Cartridge Style
GM 2 BAR MAP Sensor
Battery relocation kit
Coolant expansion tank delete kit
Retains Factory A/C
Instructions for easy installation
Note that the pictures below are of a prototype, and slight differences may exist on the production kits. (Intake/Filter is not shown in pictures, but is included in the kit.)
Old 01-11-2019, 09:27 PM
SLCviaAK's Avatar
Would other turbo options be available with this kit? Like the Borg Warner line?
Old 01-14-2019, 03:18 PM
kaze_v8's Avatar
that thing looks badass!!
Old 01-14-2019, 03:34 PM
Former Vendor
Right now we only offer Precision, we will be coming out with a T6 version within the next couple months. I suppose if the borg had the exact same dimensions it would be possible
Old 02-08-2019, 11:22 AM
dobsnek's Avatar
Any plans for a 99-06 kit? I need a kit to hang a 98mm turbo on an lsx.
Old 02-08-2019, 12:54 PM
Former Vendor
dobsnek, we will be working on one after the 14-18 kit, so we will probably be starting on it late this year
Old 02-08-2019, 08:27 PM
ZO6Ted's Avatar
Holy crap this looks nice. And the specs!
Old 02-08-2019, 09:28 PM
LaBlackIce's Avatar
Around how much is going to be the cost?
Old 02-09-2019, 08:06 PM
pcmcobra's Avatar
$7,749.99
Old 10-29-2019, 05:49 PM
esoteric_ast's Avatar
Will this fit the 2013 Tahoe?
haulin-c10
01-21-2018 11:25 AM
01WS6/tamu
07-05-2013 11:48 PM
Quick Reply: 07-13 Silverado / Sierra 1500 Bolt-on Single Turbo Kit Available For Preorder
