Hey Ron, how much would a 3.73 ring and pinion set for a 14b sf cost? I have an eaton LSD, would I need to replace anything else while changing the ring and pinion for it to work correctly with the locker? Thanks
Hi, we have the GM 9.5 3.73 gears for $179.99. They should fit your carrier fine. The master install kit is $139.99.
I ordered my set of 4.56 gears and a trutrac on the 22. I get a knock on my door just now, and the gears are already here. Thanks Ron for everything. Your service is top notch and if I ever need gears again I will give you a call.
Andy
Andy
