Gears, Posi's, Lockers, Bearings, Axles, More!
#532
Just picked up a 2008 GMC Sierra SLE regular cab short bed 2wd... GT4: rear axle with 3.73 gears... The rear is howling and I don't want to rebuild the factory carrier....
Looking at the Detroit Truetrac 913A481...
Also, an install / bearing kit?
Ship to Dallas 75209?
#533
GM 8.5 Detroit Truetrac Posi Differential 30 Spline 913A481 - Ron's Machining Service
1999-2008 GM 8.6 Master Install Bearing kit ZK GM8.6 - Ron's Machining Service
Free Shipping. Thanks!
#537
$680 delivered (48 states), Thanks!
#540
Custm2500's Rude Friend
Option code AXN will use the standard newer style 9.5 carrier parts but has 10 bolt axle bearings.
I would like to know if you have a master install kit for a 2000 Chevy Silverado GMT 800 10 bolt 8.6 rear end with axle bearings and seals??? What brand would the bearings be???
Also do you sell the Eaton Posi for the same rear end??? Would you recommend keeping the standard 400 Lbs Springs or go with the 800 Lbs Springs???
This is a daily driver with mild performance. Only driven on the street, No burn outs, but occasionally driven hard.
Can you quote that with a T&A cover and Cap Studs???
I already have gears.
Thanks!
