Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
Gears, Posi's, Lockers, Bearings, Axles, More!
Old 01-13-2014, 09:08 PM
  #561
Fastcount03's Avatar
Originally Posted by RONS MACHINING SERVICE
I will need to know the number of rear cover bolts and whether or not it has a removeable pinion support.
Thanks
14 bolt and no removable pinion support.
Old 01-16-2014, 01:00 PM
  #562
FormerVendor
RONS MACHINING SERVICE's Avatar
Ok, sounds like an 11.5.
Here are some links:
*GM 11.5 4.56 Ring and Pinion USA Standard Gear Set ZG GM11.5-456 - Ron's Machining Service
AAM 11.5" Rearend Dodge & Chevy Master Install Bearing kit R11.5RMK - Ron's Machining Service
Chevy & Dodge AAM 11.5" Helical Gear Posi Differential YP PC11.5-HELIC - Ron's Machining Service
GM 9.25 IFS 4.56 Ring and Pinion Motive Gear Set G895456IFS - Ron's Machining Service
1999-2010 GM 9.25" IFS Chevy Front Master Install Bearing kit R9.2RIFSLMK - Ron's Machining Service
Please let me know if you have any questions.
Thanks, Ron
1-800-694-3098
Old 01-17-2014, 10:45 AM
  #563
fortplainman's Avatar
dealer said my front differential has something busted in it, its locked right up. need a price on motive 4.88's with a master install kit for the 8.25 GM IFS, thanks.
Old 01-20-2014, 10:06 AM
  #564
FormerVendor
Hello, GM 8.25IFS Motive 4.88 gear and master kit will be $255.00. If you are interested, I will need to know the year.
Thanks, Ron
1-800-694-3098
Old 01-20-2014, 11:56 AM
  #565
Thanks, Ron
1-800-694-3098
2007 gmt-900(see in sig)
I bought them before from you like 3 years ago. I will find out this week once the front diff gets torn down what ill need. Thanks for the reply.
Old 01-21-2014, 09:52 AM
  #566
diesel365's Avatar
What's your price for 3.90 gear trutrac and master kit for 8.625
Old 01-22-2014, 10:14 AM
  #567
FormerVendor
Hello, $680.00 delivered.
Thanks, Ron
1-800-694-3098
Old 01-22-2014, 10:23 AM
  #568
Chevy_King1500's Avatar
looking to upgrade to a tru-trac but will be keeping the same gears.
which install kit would you recommend?
Old 01-24-2014, 08:59 AM
  #569
FormerVendor
Hello, if your truck is a 2002 chevy with a 10 bolt rear the following should fit.
GM 8.6 Carrier Install Bearing & Shim Kit - Ron's Machining Service
Thanks, Ron
Old 01-24-2014, 02:23 PM
  #570
MISTERIO's Avatar
Any 3.73 for a 2014 sierra
Quick Reply: Gears, Posi's, Lockers, Bearings, Axles, More!
