Gears, Posi's, Lockers, Bearings, Axles, More!
#82
2006 Silverado SS which Has a factory 14 bolt 9.5 SemiFloat. I am looking for Left and Right Rear axle shafts??? Are these avalible or do I have to get them from a dealer??? Do you know if they are interchangable side to side or is one side longer then the other???
Thanks for your time Rons Maching Service
Thanks
#83
Custm2500's Rude Friend
How about old body style 88-98 14 bolt 9.5 axles with 6 lug pattern. Would a company like yukon or somebody stock an axle blank and be able to cut it to length. I know they had different lengthes through out the years. I can modify the housing to use the larger old style bearing. I know its not cost effective idea but It can be done. I just need to know if the axle can be made.
#84
Slowest turbo build ever!
Hey, few questions...
First, what brand gears do you have/use? Also, what would be the price of front AND rear 3.73s/truetracs/and everything to assemble? lastly, cost of just gears and just truetracs. i work at a dealer so some of the install stuff i might be able to get a hair cheaper.
Thanks much!
Thanks much!
#85
Hey Ron, I want to place my order online, but want to make sure I'm buying the right stuff. I want a detroit trutrac, motive 4.30 gear set, master install kit, and axle bearings and seals for both sides. It's a 1500 with rear disc brakes, I saw on the site where it specified. Thank you, look forward to placing this order.
#86
Thanks Ron!
Thanks!
#87
Thanks much!
Thanks much!
1- GM 8.5 3.73 gear
1- GM 8.5 Truetrac
1- GM 8.5/8.6 master install
1- GM 8.25IFS 3.73 gear
1- GM 8.25 master install kit
Free shipping
Total: $934.99
1- GM 8.5 3.73 gear
1- GM 8.5 Truetrac
Free shipping
Total: $799.00
Just so you know, a 4.11 gear package will be about $150.00 cheaper.
Thanks!
#88
Thanks, Ron
1-800-694-3098
