Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
Shocking Deals - Fox Racing Shox! GM,JEEP,DODGE,TOYOTA,FORD
Old 05-15-2012 | 02:58 PM
PolyPerformance's Avatar
FormerVendor
Default Shocking Deals - Fox Racing Shox! GM,JEEP,DODGE,TOYOTA,FORD
Ah, got the bad joke for the day out of the way! ^^^^ ( see what I did there )
Anyway, on to the good stuff....
FOX has recently released their " Performance Series IFP" Smooth Body shocks in many common sizes, these are awesome shocks with an aluminum body starting at $127
Description:
The 2.0 Performance Series Shocks delivers race-dominating performance in a hassle free bolt-on package. Their heat-reducing design includes a metal-impacted aluminum shock body that dissipates heat faster than conventional steel. Inside the Internal Floating Piston (IFP) separates shock oil from a high-pressure nitrogen gas chamber that provides a predicable ride quality capable of handling the roughest road conditions. Combine these new technologies with a competitive price for a winning combination.
Specifications:
Body - Aluminum shock body dissipates heat three times faster than steel.
Components - Black anodized 6061-T6 billet aluminum
Shaft - 5/8" hard chrome plated heat treated alloy steel
Piston - Race-developed high-flow piston design
Valving - Application specific valving to maximize offroad performance
Seals - Redundant sealing pack system main seal, wiper seal, scraper seal
Oil - Specially formulated for ultimate performance at variable temperatures
Reservoir - Internal reservoir design separates shock oil from the high-pressure nitrogen
Mounting - Applications available for stock and aftermarket lifts kits
Adjustments:
Rebuildable
Nitrogen pressure
Compression valving
Rebound valving
FIND YOUR APPLICATION HERE ----> Poly Performance JEEP/TRUCK & BUGGY*::*Shocks & Accessories*::*Shocks*::*Fox Racing Shox*::*Application Specific - 4X4 Off-Road Parts, JK Synergy Suspension Systems, Fox Racing Shox, Beard, CNC Brakes, Johnny Joints®, Currie Enterprises, Edelbrock, P
We also stock most of the 2.0 FACTORY Series shocks as well, these are the original Fox smooth body shocks that have proven themselves year after year in some of the harshest applications on the planet.
These start at $165. The Factory series can also be had with a remote reservoir starting at $220. The reservoir adds additional fluid which helps keep the shock cooler, not to mention the reservoir can add some nice "flair" to your rig.
Fox has recently released a compression adjuster option for the remote reservoirs as well, this will run you $120 more and give you 8 clicks of compression adjustment. This is a killer idea for that multi-purpose DD or the tow rig that doubles as a DD. You can back off the adjusters for normal street driving and ramp up the compression for towing or hauling heavier loads.
The 2.0 Factory line can be found here -------> Poly Performance JEEP/TRUCK & BUGGY*::*Shocks & Accessories*::*Shocks*::*Fox Racing Shox*::*Fox 2.0" - 4X4 Off-Road Parts, JK Synergy Suspension Systems, Fox Racing Shox, Beard, CNC Brakes, Johnny Joints®, Currie Enterprises, Edelbrock, Pit Bull Tire
PM me or reply to this thread with the application / shocks you are interested in AND a zip code where we would be shipping them and I'll get you the best pricing I can offer! We are pretty competitive on FOX pricing
We can also help you with custom valving applications, JUST ASK!
In most applications, I can valve them to what you would like before shipping them out!
Also, feel free to PM/Email/Call with any questions including TECH, we are here to help!
Old 05-15-2012 | 04:09 PM
TIM Z's Avatar
11 sec. Truck Mod
Badd *** !
Do you have a set for the front of my 07 Classic Duramax CC with a 6'' Suspension lift?
My front end is " bouncy", i need more control and to firm it up a bit. If these or something you have will work lemme know thanks!
Old 05-15-2012 | 05:23 PM
FormerVendor
Pm sent!
Old 05-15-2012 | 09:44 PM
Isak81's Avatar
I need rear shocks for 2000 Chevy RCSB. It has a 2/4 Drop without a notch.
I need it to be a little firmer than stock.
Old 05-16-2012 | 12:44 PM
FormerVendor
PM Sent!
Old 05-16-2012 | 12:56 PM
Fogle07's Avatar
Front struts for 07 z71? not sure if they make them
Old 05-16-2012 | 01:18 PM
FormerVendor
PM sent!
Old 07-22-2012 | 07:59 PM
jiar577's Avatar
You have a PM
Old 07-25-2012 | 08:22 PM
Country Boy's Avatar
Senior Member
I seen about every combination but what I'm looking for. I found them for the 1500hd, 2500 and 2500hds.
2004 GMC 1500 4wd
9" of lift front and rear.
Old 12-09-2012 | 01:04 AM
TheVizena's Avatar
Registered User
2006 silverado z71 4-6 inch lift? Wasn't on the list
Quick Reply: Shocking Deals - Fox Racing Shox! GM,JEEP,DODGE,TOYOTA,FORD
