07 NNBS door speaker replacement...
#21
How do you think those JLs will work in the doors? Size/sound? I am also considering building a couple small boxes, just high enough to be flush with the trans tunnel hump laid flat on the floor so I can still use the space. My delimma is, go with the 6.5" or upsize to an 8", will I have the room in said box for either?
Of course I would have to find some good covers or fab one up. If I do that, I would want to put a small sized, 150-200 watt amp with it and maybe fit it under the driver seat. Whats a good small size (Dimensions)?
I like for things to be hidden for a cleaner look and for security. Tint will be applied also. I like for things in the interior to look like it was put there from factory, Useing the whole bed for speakers is not the direction I would go. I just want it to sound good and clear with a little bump for double bass.
Thanks fo the info.
Thanks fo the info.
